zeldapinwheel
#1 Posted : Wednesday, January 13, 2010 6:33:02 AM(UTC)
zeldapinwheel
Is there a step by step instructional guide to replacing the heating element for this Maytag dryer?
#2 Posted : Wednesday, January 13, 2010 4:07:08 PM(UTC)
This part is not too difficult to replace. Remove the two screws on the bottom of the front panel. Grab the front panel on the bottom with two hands and pull it up for about 45° angle to release the front panel from the tabs on the top. Remove the wires from the door switch and put the front panel aside. Remove the wires from the heater assembly (draw a picture of them for yourself). Remove the screws holding the heater assembly and pull it out. You can replace the just the heating element all the whole assembly (more money - less headache).
- The heating element Part number: AP4289952
- The heater assembly Part number: AP4290655
New Kenmore Elite 796 Gas Dryer Won't Heat (Dryer Repair)
by Guest 12/26/2022 1:54:20 PM(UTC)
Whirlpool Duet Dryer won't heat anymore (Dryer Repair)
by Guest 3/31/2021 5:35:15 AM(UTC)
Dryer won't heat consistently – Is an RCA model dryer actually GE? (Dryer Repair)
by OpsTao 12/11/2020 7:20:38 AM(UTC)
Samsung Dryer Won't heat no matter what I do (Dryer Repair)
by coachroy 10/16/2020 10:58:40 AM(UTC)
Whirlpool LGT7848AQ1 dryer won't heat (Dryer Repair)
by spiggman 9/19/2020 4:47:12 PM(UTC)
Kenmore Electric Dryer Won't Heat (Dryer Repair)
by ginakra 9/21/2017 11:03:29 AM(UTC)
Dryer won't heat (Dryer Repair)
by ncoles6 12/23/2016 6:32:33 PM(UTC)
Whirlpool Dryer won't heat (Dryer Repair)
by spelding 9/16/2016 5:48:12 AM(UTC)
by Kate123 3/5/2016 7:28:08 AM(UTC)
Stumped - Samsung Dryer Won't Heat (Dryer Repair)
by TankusKC 1/6/2016 8:18:18 AM(UTC)
by haymon 1/5/2016 5:47:24 PM(UTC)
by wgomezp1 10/12/2015 4:49:48 PM(UTC)
by chash 8/6/2015 9:12:57 AM(UTC)
Gas dryer won't heat (Dryer Repair)
by pino2424 4/21/2015 5:45:55 PM(UTC)
A different my dryer won't heat problem (Dryer Repair)
by mikeysotp 11/20/2014 5:05:34 AM(UTC)
