Have not used the oven in 6 months. When I turned on the oven it heated ok, but when I tried to turn it off it did not turn off. A low flame continued. What could be the problem?
Thanks for any ideas.
Wilbern Michalk
Possible the gas safety valve got stuck open. Try to tap on it when it would not turn off. The model number you posted is incomplete. Verify and repost it.
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
