had low flame on all burners and in oven , checked supply it was good and replace the supply valve and still no change. I cleaned all orifices and am now at a loss as to what could be causing it.
Any suggestions?
Sounds like you have a bad regulator or low gas pressure going to unit....
Originally Posted by: HumboldtRepairMan ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Sounds like you have a bad regulator or low gas pressure going to unit.... Gas company checked pressure at supply line and it was good, I replaced the Pressure valve PART NUMBER: WB19K28 and no change. Not sure, but i believe that is the pressure regulator valvle I replaced. Thanks though any other thoughts?
have you recently changed this unit from propane or to propane at all?
Originally Posted by: HumboldtRepairMan ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) have you recently changed this unit from propane or to propane at all? Sorry did not mention that it is propane and has been since new
And you have the new regulator put in the LP position? There should be a switch somewhere on it......also did you change the orfice out of the regulator and put the LP orfice in the new regulator you installed?
Originally Posted by: HumboldtRepairMan ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) And you have the new regulator put in the LP position? There should be a switch somewhere on it......also did you change the orfice out of the regulator and put the LP orfice in the new regulator you installed? Didn't think about that, is it the brass plug/nut on the side of the regulator? I changed the orifice to LP and no change. I could not find a switch, but the stove worked fine until a few weeks ago. I even changed the safety valve today just to be sure. and replaced the supply line to. It lights just fine then the flame goes very small. This is the case on all four burner and the oven.
