m.deanda@verizon.net
#1 Posted : Tuesday, December 29, 2009 9:25:22 AM(UTC)
The motor sounds like it turning faster then the drum is spining
How do I open the dryer to investigate?
sidfink43
#2 Posted : Wednesday, December 30, 2009 5:41:23 PM(UTC)
sidfink43
It is easy to get into this model, except for the tight space where you reach in to release the idler pulley. It will take some time, and be sure and note where all the screws go.
This service manual will show you how to remove the top, front and bulkhead to get to the drum.
Sounds like you may have a bad belt.
http://www.servicematters.com/m...ibrary/docs/16025911.pdf
Maytag Neptune clicks/creaks/groans at low spin speeds but not at high speeds (Washer Repair)
by fixitboy 7/3/2024 1:06:24 PM(UTC)
Maytag Neptune mah9700a won't drain ...(locking issue?) (Washer Repair)
by Mr.Petes 8/4/2023 4:55:48 AM(UTC)
Maytag Neptune wont high spin under load (Washer Repair)
by jim20j 2/24/2023 9:23:15 AM(UTC)
Maytag Neptune Stacklable (Washer Repair)
by johnafoy@yahoo.com 2/7/2023 11:34:24 AM(UTC)
MAYTAG NEPTUNE STACKED - GAS - NOT SPINNING (Washer Repair)
by ccalderon70 1/9/2023 9:09:40 AM(UTC)
Lr code on my Maytag Neptune Front Load Washer (Washer Repair)
by Guest 11/19/2022 9:53:55 AM(UTC)
Maytag Neptune Front Load Washer “do” code (Washer Repair)
by Guest 12/25/2021 2:22:33 PM(UTC)
maytag neptune MAH21PD tumbles during spin (Washer Repair)
by joedonovan 11/22/2021 4:27:39 PM(UTC)
maytag neptune MAH21PD (Washer Repair)
by Guest 11/22/2021 4:23:11 PM(UTC)
Maytag Neptune MAH5500AWW (Washer Repair)
by Bubdad1 4/19/2021 4:49:41 AM(UTC)
Maytag Neptune DC (Drying Center) gas dryer mcg8000aww Flame not staying on (Dryer Repair)
by chanash 12/15/2020 3:00:11 PM(UTC)
maytag neptune motor spins too fast (Washer Repair)
by jbmur 11/27/2020 7:25:55 PM(UTC)
Maytag Neptune MAH8700 Repair (Control Board) (Washer Repair)
by kicaza 11/17/2020 9:45:19 AM(UTC)
Maytag Neptune washer stops and won't unlock (Washer Repair)
by dctaz37 9/13/2020 5:18:38 PM(UTC)
Maytag Neptune runs cold and hot but not warm (Washer Repair)
by mikecinmaine 7/25/2020 6:32:28 AM(UTC)
