Freezer not freezing and makes Poping sound! Refrig. side cools but not real cold. Help:confused:
Quote:...makes Poping sound... Can you be more specific on that? Gene.
Poping sound or cracking type sound coming from between outside skin and the inside. Compresser and fan are running. Just not freezing but it's cool even if I turn to coldest setting.
Originally Posted by: Gene  No but just above the coils between the coils and the fan some thing is covered with ice.
No wires look ok removed panels inside no ice on coils But between coils and fan is ice what is it covering ? I dont know. Will not freeze stuff inside What now? :confused:
You have refrigeration problems for a pro. to look at.
