kathyb53
#1 Posted : Saturday, December 12, 2009 8:47:47 AM(UTC)
kathyb53
Hello Denman, I was reading your earlier post but I am too stupid to understand completely. To jump the thermal fuse, I connect the two red wires that go in on one side of the thermal fuse but do nothing to the other side? Is that correct?
magician59
#2 Posted : Saturday, December 12, 2009 4:15:33 PM(UTC)
magician59
To temporarily jump a thermal fuse or a thermostat, connect the (larger) wire going to the component with the one going from it. Make sure you securely wrap it with electrical tape, so the terminals don't make contact with any other metal during your test. Test only one component at a time. Be confident, but above all, [COLOR="Red"]BE SAFE[/COLOR]!
kathyb53
#3 Posted : Saturday, December 12, 2009 5:26:21 PM(UTC)
kathyb53
Thank you. Jumping across the thermal fuse proved the problem is the thermal fuse. But I can't figure out how to get it out. so I think I have to buy a new dryer. Would it bepermissible to attach a new thermal fuse, wrap the connections with elec. tape and secure it to the back panel with tape instead of pulling the old one out? I just appreciate your help. I enjoy taking things apart and sometimes I actually get something fixed! thank you so much!
magician59
#4 Posted : Saturday, December 19, 2009 8:59:32 AM(UTC)
magician59
Most thermal fuses are attached with only one hex head screw. After removing the screw, lift it up at the screwed end, swinging it out of the slot, where it hooks in.
Maytag Dryer shutting off after 2 minutes (Dryer Repair)
by Guest 11/9/2023 4:45:11 AM(UTC)
maytag dryer MEDC200XW1 (Dryer Repair)
by patnok 9/4/2023 8:02:13 AM(UTC)
Replaced belt, idler pulley, and rollers and now Maytag Dryer Wont Start (Dryer Repair)
by Guest 11/29/2022 8:43:07 PM(UTC)
Maytag Dryer MGD7230HW2 LP CONVERSION HELP!! (Dryer Repair)
by prodigey 10/14/2022 3:54:00 AM(UTC)
Maytag dryer (Mode MEDC300XW1) not starting, but runs only in Wrinkle Prevent cycle. (Dryer Repair)
by Guest 7/28/2022 6:31:22 PM(UTC)
Maytag dryer won't stop on timed dry (Dryer Repair)
by eaglemtn 11/11/2021 5:35:16 PM(UTC)
Maytag Dryer Slow to Spin after parts replacement (Dryer Repair)
by steelwindmachine 8/18/2021 5:58:15 AM(UTC)
Maytag Dryer not drying. Flame shuts off after 20-30 seconds (Dryer Repair)
by jbschwartz 6/27/2021 4:54:19 PM(UTC)
Maytag dryer MDE9316ATA (Dryer Repair)
by Guest 5/1/2021 3:45:42 PM(UTC)
Maytag Dryer (Bravos) (Dryer Repair)
Belarus Kap61 3/29/2021 4:03:51 PM(UTC)
Maytag Dryer *usually* won't heat (Dryer Repair)
by ab52 6/12/2020 12:20:59 PM(UTC)
Maytag Dryer Starts But No Heat (Dryer Repair)
by boonie785 6/1/2020 3:32:33 PM(UTC)
Maytag dryer stops early (Dryer Repair)
by J-fixtit 5/28/2020 6:59:15 PM(UTC)
Maytag dryer dont start (Dryer Repair)
by jzemer 5/16/2020 5:58:30 PM(UTC)
MAYTAG dryer loud squealing/squeaking (Dryer Repair)
by joenobodyyet 3/24/2020 1:27:25 PM(UTC)
