ebontrager
#1 Posted : Tuesday, November 17, 2009 6:28:35 PM(UTC)
ebontrager
This dryer all of a sudden started not heating. I have previously about 8 years ago replaced the heating element. I figured it had gone out again. I went ahead and got another one and replaced it. Still no heat. I'm wondering what I should check now to see what the problem is. Any help would be appreciated.
Eric
sidfink43
#2 Posted : Thursday, November 19, 2009 1:29:57 PM(UTC)
sidfink43
Hi Eric
Check to make sure you have 120v coming to each side of the connection block. The dryer will run but not heat if you have only 120v on one side.
If that is ok, check these parts for continuity. Replace both if one fails.
Part number: AP3094224
Finally check your operating thermostat which is on the blower cover.
That should do it.
ebontrager
#3 Posted : Friday, November 20, 2009 10:06:28 AM(UTC)
ebontrager
That did it. It was the small one. I replaced both and good to go. Thanks
sidfink43
#4 Posted : Friday, November 20, 2009 10:37:43 AM(UTC)
sidfink43
Great, glad you got it fixed and thanks for updating us.
New Kenmore Elite 796 Gas Dryer Won't Heat (Dryer Repair)
by Guest 12/26/2022 1:54:20 PM(UTC)
Whirlpool Duet Dryer won't heat anymore (Dryer Repair)
by Guest 3/31/2021 5:35:15 AM(UTC)
Dryer won't heat consistently – Is an RCA model dryer actually GE? (Dryer Repair)
by OpsTao 12/11/2020 7:20:38 AM(UTC)
Samsung Dryer Won't heat no matter what I do (Dryer Repair)
by coachroy 10/16/2020 10:58:40 AM(UTC)
Whirlpool LGT7848AQ1 dryer won't heat (Dryer Repair)
by spiggman 9/19/2020 4:47:12 PM(UTC)
Kenmore Electric Dryer Won't Heat (Dryer Repair)
by ginakra 9/21/2017 11:03:29 AM(UTC)
Dryer won't heat (Dryer Repair)
by ncoles6 12/23/2016 6:32:33 PM(UTC)
Whirlpool Dryer won't heat (Dryer Repair)
by spelding 9/16/2016 5:48:12 AM(UTC)
by Kate123 3/5/2016 7:28:08 AM(UTC)
Stumped - Samsung Dryer Won't Heat (Dryer Repair)
by TankusKC 1/6/2016 8:18:18 AM(UTC)
by haymon 1/5/2016 5:47:24 PM(UTC)
by wgomezp1 10/12/2015 4:49:48 PM(UTC)
by chash 8/6/2015 9:12:57 AM(UTC)
Gas dryer won't heat (Dryer Repair)
by pino2424 4/21/2015 5:45:55 PM(UTC)
A different my dryer won't heat problem (Dryer Repair)
by mikeysotp 11/20/2014 5:05:34 AM(UTC)
