Washer is leaking at the bottom of the tub. Could it be the Seal Kit? It only leaks when it is in the wash cycle. Not when it is filling or letting out. Wonder on the cost of labor for this type of job......would it be better to just buy new?
Hello,
From the bottom center of the tub, then you will need a new stem seal kit.
Do you have any idea if that is labor intensive?
