Rob Sut
#1 Posted : Monday, November 9, 2009 9:05:31 AM(UTC)
Rob Sut
Im getting power to the dryer, but when I hit the start button and hold it down it will not start. It does make a dull clicking sound, almost like it is lightly cold cranking like a car (bad example) but it sounds like it is holding back. Thx
sidfink43
#2 Posted : Tuesday, November 10, 2009 3:22:17 PM(UTC)
sidfink43
See if the drum will turn easily by hand. If it will, have someone hold the door switch in while you push the start button and try to turn the drum. If it starts up your motor is probably bad.
If it will not turn easily by hand take off the bottom service panel and see if the belt is hung up or broken and trapped in some way.
Rob Sut
#3 Posted : Saturday, November 14, 2009 6:02:05 AM(UTC)
Rob Sut
Tried, Doesnt turn on and moves freely.
sidfink43
#4 Posted : Saturday, November 14, 2009 1:28:58 PM(UTC)
sidfink43
Ok, this is good as it suggest the motor is not the problem, and the motor is an expensive repair part.
I would focus on the push to start switch, which you can replace very inexpensively,
Part number: AP3080767
If that does not solve the problem by pass the door switch and see if that works. After that you should start testing the internal thermal fuses and thermostats which you can access from the lower service panel.
and the door switch, which you can test by
Replaced belt, idler pulley, and rollers and now Maytag Dryer Wont Start (Dryer Repair)
by Guest 11/29/2022 8:43:07 PM(UTC)
Maytag Dryer wont start (Dryer Repair)
by rscottc 5/27/2018 10:49:05 PM(UTC)
GE Dryer wont start (Dryer Repair)
by bob35614 2/13/2017 4:21:03 PM(UTC)
Roper Dryer wont start. Not sure of the problem. (Dryer Repair)
by roadkill721 3/18/2016 4:39:05 PM(UTC)
maytag legacy dryer wont start (Dryer Repair)
by kennypkay 11/15/2015 2:02:45 PM(UTC)
Admiral Dryer wont start (Dryer Repair)
by chargitt 8/24/2015 1:25:34 PM(UTC)
kenmore dryer wont start (Dryer Repair)
by coindog1 7/26/2015 12:33:16 PM(UTC)
by antoine123 6/10/2015 5:23:52 PM(UTC)
dryer contol lock is locked -dryer wont start (Dryer Repair)
by k62254 5/29/2015 1:10:18 PM(UTC)
Maytag electric dryer wont start (Dryer Repair)
by HammerSings 3/12/2015 5:22:07 PM(UTC)
Whirlpool dryer wont start (Dryer Repair)
by laundry1 1/20/2015 11:46:37 AM(UTC)
dryer wont start (Washer Repair)
by rangerleader63@gmail.com 9/4/2014 7:56:01 AM(UTC)
by mich01 9/1/2014 4:17:03 PM(UTC)
maytag dryer wont start (Dryer Repair)
by clavin29 3/1/2014 7:22:21 AM(UTC)
by cnrimgr1 2/17/2014 12:27:23 PM(UTC)
