Need Assiatance Please"
I have found water at freezer floor and suspect it came from ice maker water dispenser, this happened months ago. Ice maker worked still after that. When it stopped working I took out ice maker and found ice in tray and brown ice underneth ice tray which I cleaned. I put heated air into water dispense tube with hair dryer and seemed like no blockage, when I close the light flap with switch in "on" position the light stays solid red.
Ideas?
Ideas? Forgot to mention that water dispenser is not working.
