jdrake97
#1 Posted : Thursday, October 15, 2009 6:34:51 PM(UTC)
jdrake97
My dryer is 12 yrs old and I took it apart to clean and replace the belt. After putting it back together and turned it on the breaker blew. I turned the heat off and the motor and drum work fine but after turning on the element again the breaker blew. I followed the wiring diagram and even took a picture of all the connections so I would not get any of them confused. I ran a continuety test on all systems and only thing I found was the thermal fuse was blown due to the short that blew the breaker. Agian after replacing the thermal fuse, I blew it again by trying to run the dryer. Any ideas? Thanks!
#2 Posted : Friday, October 16, 2009 4:37:19 AM(UTC)
Could be that the heating element may have moved/sagged and is touching the case. Could be that it broke and is now shorting to the case.
Unplug the unit.
Remove the wires from the heating element.
Measure the element usually around 10 ohms.
Then measure from each terminal to the case/frame both should be open (infinite ohms)
Amana Dryer (ned4655ew1) vent glows when door is open (Dryer Repair)
by Guest 7/2/2024 9:31:47 AM(UTC)
Amana dryer motor growl at startup (Dryer Repair)
by Guest 9/21/2023 3:35:28 AM(UTC)
Amana Dryer (NED4600YQ1) Heating Element not heating (Dryer Repair)
by vckiran1 12/29/2019 6:06:10 AM(UTC)
Amana dryer not heating (Dryer Repair)
by keepingwiththetimes 2/7/2018 2:53:54 PM(UTC)
Amana Dryer not heating (Dryer Repair)
by HnRmom 4/27/2017 6:09:54 PM(UTC)
Amana Dryer won't start, but still gets hot (Dryer Repair)
by halfmoonranch 3/15/2017 9:38:33 AM(UTC)
Amana dryer flipping breaker (Dryer Repair)
by Wumford 8/13/2016 12:43:25 PM(UTC)
Amana Dryer Error Code TS (Dryer Repair)
by DaleW 7/14/2016 6:47:27 AM(UTC)
Amana dryer will not shut off on automatic cycles (Dryer Repair)
by Nutforbriggs 4/21/2016 11:42:33 AM(UTC)
Amana Dryer NED7200TW Not Drying/Heating Up (Dryer Repair)
by Bappy 4/6/2015 3:40:10 PM(UTC)
AMANA dryer runs continuously on automatic cycles (Dryer Repair)
by crussev 7/17/2014 5:23:43 AM(UTC)
Amana Dryer Dead (Dryer Repair)
by Jonas76 7/2/2014 5:29:02 PM(UTC)
Amana Dryer won't run (Dryer Repair)
by Paige Tremblay 1/26/2014 6:06:08 AM(UTC)
Amana Dryer won't heat (Dryer Repair)
by bangacan 11/28/2013 10:57:32 AM(UTC)
Amana Dryer keeps blowing thermostat (Dryer Repair)
by dfrye 11/27/2013 6:56:02 PM(UTC)
