DEEDEEGOGO
#1 Posted : Thursday, October 15, 2009 11:49:33 AM(UTC)
DEEDEEGOGO
After wash cycle is complete the washer will not go in to high speed spin.
Went through diagnostic procedure & machine did high speed spin then
flashed E-47 code. The next procedure was to remove the door lock assembly (which i did) & measure the resistence of the PTC circuit.
Where exactly do you measure this? I checked the ohms at the wax motor
and have 5.87K & at the plug 500K.
#2 Posted : Thursday, October 15, 2009 3:12:52 PM(UTC)
PTC states for "Positive Temperature Coefficient" or in other word it is a wax motor in this case. According to the Tech sheet the test results you posted looks like the problem is a bad door lock assembly.
- The door lock Part number: AP4455026
DEEDEEGOGO
#3 Posted : Friday, October 16, 2009 12:35:53 PM(UTC)
DEEDEEGOGO
Thanks GENE for your help! I wasn't sure if the door lock was bad, but I was leaning that way. I ordered the part & when it comes in I'll let you know if it works.
Frigidaire washer not draining, no high speed spin (Washer Repair)
by Stheemka 3/24/2020 6:39:56 AM(UTC)
No high speed spin - E58 (Washer Repair)
by bobw462 10/5/2014 6:25:12 PM(UTC)
No high speed spin (Washer Repair)
by Motorat 9/13/2013 9:40:27 PM(UTC)
no high speed spin (leaves things too wet) (Washer Repair)
by sgm1115 1/28/2013 4:32:34 PM(UTC)
by Blake1111 6/23/2010 3:03:16 PM(UTC)
by surferfletch 1/14/2010 2:52:04 PM(UTC)
Kenmore Front Load Washer - No High Speed Spin (Washer Repair)
by BLKJAK 10/13/2009 7:36:26 PM(UTC)
Front loader no high speed spin (Washer Repair)
by richappy 9/29/2009 1:44:47 PM(UTC)
