2 Pages12>
gvazquez
#1 Posted : Friday, October 2, 2009 10:46:51 AM(UTC)
gvazquez
I have a kenmore 80 series washer model 110.23832100. The timer goes through the entire cycle but the washer only goes through the wash cycle. No rince or spin cycle. Also i had noticed in the last few weeks when it did go through all the cycles, the clothes would still be partially soaked. i'm not sure whether it was not completely draining or spinning thoroughly.
HELP!!!:confused:
Thanks,
Gilbert
#2 Posted : Friday, October 2, 2009 2:47:17 PM(UTC)
Gilbert,
Does it drain?
gvazquez
#3 Posted : Friday, October 2, 2009 3:42:40 PM(UTC)
gvazquez
Gilbert,
Does it drain?
No, it doesn't drain. it fills, washes then just stops aggitating when the timer reaches the end.
Gilbert
#4 Posted : Friday, October 2, 2009 3:46:46 PM(UTC)
The first thing i would do is check the lid switch (#11 on the diagram).
- The lid switch Part number: AP3100001
gvazquez
#5 Posted : Friday, October 2, 2009 3:49:52 PM(UTC)
gvazquez
No, it does not drain. It fills, washes then just stops aggitating when the timer reaches the end. it does the same thing on all cycles.
Gil
gvazquez
#6 Posted : Friday, October 2, 2009 3:53:36 PM(UTC)
gvazquez
is it pretty much a open/close circuit switch or is there more to it? can i just just check for continuity?
#7 Posted : Friday, October 2, 2009 6:00:49 PM(UTC)
The first thing you can check if it does click when you close the lid. You can check it for continuity as well.
duckdog_3a
#8 Posted : Sunday, April 11, 2010 9:11:34 AM(UTC)
duckdog_3a
My washer will do the same as Gilberts, but I will have to run the spin cycle to get the rest of the water out. Could this also be caused by the lid switch and how can I test it to make sure?
Any help would be great!!
Thanks,
#9 Posted : Tuesday, April 13, 2010 12:15:08 PM(UTC)
Tim,
What is the complete model number of the washer?
duckdog_3a
#10 Posted : Wednesday, April 14, 2010 6:01:23 PM(UTC)
duckdog_3a
Gene,
It is a Kenmore series 80 model 110:23832100
Sorry forgot to put that in there.
Tim
Guest (4)
Kenmore 80 Series washer, fast speed burning smell (Washer Repair)
by lwmi5870 3/9/2024 1:25:21 PM(UTC)
Kenmore 80 Series 110.24862300 - Does Not Agitate or Spin (Washer Repair)
by mjcotter 8/13/2023 9:41:35 PM(UTC)
Kenmore 80 series won’t spin making grinding noise and smells burnt (Washer Repair)
by Liciasmommy 5/29/2021 2:00:00 PM(UTC)
Kenmore 80 Series 11023822100 won't spin (Washer Repair)
by G.1 11/17/2019 3:30:42 PM(UTC)
Mystery Part: Kenmore 80 series (Washer Repair)
by Jg2000 3/6/2018 2:59:15 PM(UTC)
Kenmore 80 series heavy duty plus washer (Washer Repair)
by T-D-G 9/3/2016 4:56:32 PM(UTC)
Kenmore 80 Series Scorched Wires (Washer Repair)
by Dubont 1/30/2016 3:53:25 PM(UTC)
kenmore 80 series will not stay running (Dryer Repair)
by super3sr 1/24/2016 10:40:13 AM(UTC)
Kenmore 80 series washer agitating but not draining (Washer Repair)
by avai 9/8/2015 5:18:42 PM(UTC)
Kenmore 80 Series won't spin - no motor sound (Washer Repair)
by mkdwns 9/8/2015 4:57:50 PM(UTC)
Kenmore 80 series agitates slowly and won't spin (Washer Repair)
by Heather68 8/24/2015 12:13:20 PM(UTC)
Kenmore 80 series washer (Washer Repair)
by c00lhand 8/24/2015 10:41:31 AM(UTC)
Kenmore 80 Series won't turn. Belt good (Dryer Repair)
by 124sport 6/7/2015 4:17:48 PM(UTC)
Kenmore 80 Series...Dryer Wont Heat... Tested/continuity good (Dryer Repair)
by xtacbyme 6/3/2015 7:57:15 PM(UTC)
KENMORE 80 series wet clothes after spin cycle (Washer Repair)
by APPLIANCEDUDE1972 4/22/2015 4:05:46 PM(UTC)
2 Pages12>
