trish949
#1 Posted : Saturday, September 26, 2009 7:33:08 AM(UTC)
trish949
my frigidaire crown dryer all of a sudden wont heat up to dry clothes, clean all areas still no heat. is there a fuse or something that we can replace and if so how and where is it at.
sidfink43
#2 Posted : Sunday, September 27, 2009 4:50:28 PM(UTC)
sidfink43
First check to make sure that you have 120v coming to each side of the connection block
Then unplug the dryer and insert a putty knife or screw driver in the gap between the top and front near the edges. This will release clips that hold the top to the cabinet and it will flip up. Then take off the front. This will expose the heater asembly and the blower cover which will have thermostats/thermal fuses for you to check for continuity.
Finally check the heating element for a break.
Whirlpool Inglis Dryer Wont Heat Up and Keeps Running (Dryer Repair)
by johnnymac813 1/8/2014 4:39:14 PM(UTC)
Dryer Wont Heat Up (Dryer Repair)
by SUE KLEIN 8/24/2013 6:22:08 AM(UTC)
dryer wont heat up (Dryer Repair)
by lmyers 3/11/2013 12:31:55 PM(UTC)
Gas dryer wont heat up (Dryer Repair)
by kramler92 12/8/2011 3:14:26 PM(UTC)
by beachrunner 8/15/2011 8:56:07 AM(UTC)
Neptune Dryer wont heat up or dry (Dryer Repair)
by medik3 8/4/2011 8:13:36 AM(UTC)
dryer wont heat up at all (Dryer Repair)
by dcquick1096 12/2/2010 7:30:44 AM(UTC)
Dryer wont heat up (Dryer Repair)
by ktventura1989@yahoo.com 7/9/2010 2:32:48 PM(UTC)
Whirlpool Elec Dryer wont heat up (Dryer Repair)
by Canute 2/9/2010 3:16:11 PM(UTC)
by tam4572@aol.com 2/7/2010 3:22:11 AM(UTC)
dryer wont heat up? (Dryer Repair)
by jreich77 11/1/2009 4:33:01 PM(UTC)
Ge dryer wont heat up (Dryer Repair)
by CLARK12 8/2/2009 12:36:31 PM(UTC)
by poelease 6/4/2009 8:22:16 AM(UTC)
by NYSE Bob 5/21/2009 5:33:26 PM(UTC)
Whirlpool Imperial series gas dryer wont heat up.. (Dryer Repair)
by NBK 4/6/2009 3:36:45 PM(UTC)
