sweettea
#1 Posted : Wednesday, September 23, 2009 9:39:22 AM(UTC)
sweettea
i have problem with my dryer heating up also my timer will not turn blowing cold air and tub moves
#2 Posted : Thursday, September 24, 2009 2:18:18 AM(UTC)
Replacement parts for WHIRLPOOL LER5636PQ0 | AppliancePartsPros.com
Here is a wiring diagram
http://www.servicematters.com/d...0Sheet%20-%208528187.pdf
Try the unit in timed dry mode.
If the timer still does not advance you may have a power problem.
Note that both the heater and timer motor run off of the 240 volts.
Turn the breaker off/on slowly a couple times. Better yet check it with a meter.
If it does turn then it could be the heater is blown.
In auto modes the voltage for the timer goes through the heating coil.
Easiest way to check it is with a meter.
GE Dryer not heating up (Dryer Repair)
by Dryernoob 4/23/2020 10:55:51 AM(UTC)
electric whirlpool dryer not heating up (Dryer Repair)
by jumpnchuck 10/30/2013 6:31:51 PM(UTC)
Estate dryer not heating up (Dryer Repair)
by Jackier 8/6/2013 5:23:00 PM(UTC)
Amana Dryer not heating up after we moved into new home (Dryer Repair)
by clr0221 7/10/2013 5:33:00 PM(UTC)
frigidaire gallery series dryer not heating up (Dryer Repair)
by Oblivion 4/27/2013 7:56:33 AM(UTC)
Whirlpool dryer not heating up (Dryer Repair)
by MKrieck 7/22/2012 6:37:03 PM(UTC)
by moorece8 5/9/2012 5:28:21 AM(UTC)
Whirlpool Dryer Not heating up (Dryer Repair)
by rrussell@erols.com 4/25/2012 12:18:22 PM(UTC)
Kenore dryer not heating up (Dryer Repair)
by Thog137 11/16/2011 9:56:09 AM(UTC)
Maytag Dryer not heating up properly (Dryer Repair)
by BobG68 10/23/2011 11:45:22 PM(UTC)
Stackablw dryer not heating up/ (Dryer Repair)
by hayatsinc 5/14/2011 3:11:46 PM(UTC)
roper dryer not heating up help (Dryer Repair)
by heather608 3/18/2011 5:01:11 PM(UTC)
by scoffman1234 3/16/2011 1:36:37 PM(UTC)
Amana electric dryer not heating up (Dryer Repair)
by Ultraman50 1/6/2011 6:58:54 PM(UTC)
Maytag electric dryer not heating up (Dryer Repair)
by jmlpa 12/7/2010 9:41:11 AM(UTC)
