fishyfingers
#1 Posted : Friday, January 25, 2008 4:00:58 AM(UTC)
fishyfingers
I Have A Coloric Stove & Oven, When I Turn The Oven Control Knob To The Bake Position & The Temp Up To Lets Say 350 Degrees The Oven No Longer Heats Up, I Removed The Drip Pan Covering The Ignighter At The Bottom Of The Oven, The Ignighter Which Is Electric, It Is Glowing Orange, But No Gas Is Flowing Thru The Gas Tube Near The Ignighter, And There Is No Flame. The Propane Tank Is Ok Because All 4 Top Burners Work Fine.
Where Should I Start Looking For The Problem??????
Fishyfingers
kawfeeman
#2 Posted : Friday, January 25, 2008 4:35:04 AM(UTC)
kawfeeman
you should start by measuring amperage of the ignitor ... ( usually, if you leave the oven on for 5-15 minutes, it may actually come on ) most often that is the indication that the ignitor is not drawing enough amperage to actually open the valve. HOWEVER, we dont suggest that with LP ... I'd begin with the ignitor ...
fishyfingers
#3 Posted : Friday, January 25, 2008 6:28:41 AM(UTC)
fishyfingers
thanks kawfeeman!!
what should the amperage measure? and what wires do you test, both wires at the ignitor or 1 wire and ground, the ignitor is glowing bright orange and i left it on for 25 min and still did'nt light.
thanks again
kawfeeman
#4 Posted : Friday, January 25, 2008 7:10:13 AM(UTC)
kawfeeman
just measure one wire going to the ignitor with an AMPROBE, not a volt meter .. you'll need a clamp on device to measure inductively the current draw... ( remember "bright orange" is relative... may not be as bright as a newer ignitor )
fishyfingers
#5 Posted : Friday, January 25, 2008 7:53:00 AM(UTC)
fishyfingers
i will measure the amperage when i get home, what amperage should i be looking for at the ignitor feed wire . i have an amprobe and i will test that tonight. i have an electrical background from the marine field 26 years, it helps a bit. if you can give me an amperage # to look for when testing and it tests good, where would i look next. i will write down the mod# to help in the future, but i do not have the mod # with me today.
thanks in advance!!!!!!
fishyfingers
fishyfingers
#6 Posted : Monday, January 28, 2008 3:50:59 AM(UTC)
fishyfingers
Hello Kawfeeman
Hope You Can Help!!
I Did Test The Amperage At The Ignitor Wire And Found 3.42 Amps While The Ignitor Was Glowing, Tested Both Wires, 1 At A Time And The Reading Is The Same.
Thanks In Advance!!
Fishyfingers.
RegUS_PatOff
#7 Posted : Monday, January 28, 2008 9:24:37 AM(UTC)
RegUS_PatOff
that seems about right, but a model number would be more helpful
Whirlpool WFG505MOBS0 - Oven Won't Light (Oven Repair (including Ranges and Cooktops))
by JeffraKing 11/15/2023 9:09:08 AM(UTC)
Thermador Gas oven won't light (Oven Repair (including Ranges and Cooktops))
by Guest 8/1/2023 8:48:27 AM(UTC)
Amana oven won't light (Oven Repair (including Ranges and Cooktops))
by rope13 1/10/2017 3:55:40 PM(UTC)
Help, my gas oven won't light..... (Oven Repair (including Ranges and Cooktops))
by lharrell79 3/17/2016 10:13:10 AM(UTC)
Oven won't light, hear click(s), no gas smell (Oven Repair (including Ranges and Cooktops))
by gizmodyne 4/26/2015 6:36:01 AM(UTC)
Kitchenaid Gas Oven Won't Light (Oven Repair (including Ranges and Cooktops))
by Chris Ricc 1/7/2015 8:13:37 PM(UTC)
Oven won't light (Oven Repair (including Ranges and Cooktops))
by davidr222 7/31/2014 7:01:18 AM(UTC)
Magic Chef Oven Won't Light (Oven Repair (including Ranges and Cooktops))
by miisu 1/21/2014 4:55:33 PM(UTC)
Oven won't light; shuts off with F2 Error during pre heat (Oven Repair (including Ranges and Cooktops))
by MaxRock 11/21/2013 2:12:32 PM(UTC)
Whirlpool Oven Won't light (Oven Repair (including Ranges and Cooktops))
by klucich 5/13/2013 4:36:10 AM(UTC)
Frigidaire oven won't light (Oven Repair (including Ranges and Cooktops))
by baltojeff 12/7/2012 6:58:35 AM(UTC)
Roper Oven won't light (Oven Repair (including Ranges and Cooktops))
by LoneMedic 11/9/2012 10:15:54 AM(UTC)
gas broiler and oven won't light (Oven Repair (including Ranges and Cooktops))
by rickric 8/27/2012 4:16:55 PM(UTC)
GE Profile, oven won't light (Oven Repair (including Ranges and Cooktops))
by Buggus 8/1/2012 4:05:34 AM(UTC)
by gregew 7/10/2012 7:47:10 AM(UTC)
