mariner
#1 Posted : Sunday, January 20, 2008 4:24:34 PM(UTC)
mariner
Washer begins to spin, but stops only after 2 - 3 seconds. The belt is intact, but shows normal wear (some cracks etc). The tub is not out of balance. It keeps trying to start the spin cycle after a few minutes but stops. Any help is greatly appreciated!
#2 Posted : Monday, January 21, 2008 10:21:58 AM(UTC)
Remove the belt and check if the motor runs without load.
mariner
#3 Posted : Monday, January 21, 2008 8:45:29 PM(UTC)
mariner
I removed the belt. It definitely needs to be replaced. It is not broken, but it has multiple cracks almost all the way through. The motor seems to run just fine without the belt on it. Does this mean that if the belt is replaced the washer should spin again. If not, what are the next steps.
Thank you for your help.
#4 Posted : Tuesday, January 22, 2008 2:09:01 PM(UTC)
There is a good chance the new belt will solve the problem.
- The part number for the belt is AP74961
Here are the break down diagram for the Amana washer Model LW3503W
Good luck.
mariner
#5 Posted : Saturday, January 26, 2008 10:17:32 AM(UTC)
mariner
I replaced the belt. Initially, the machine kept stalling. It took 4 or 5 tries before it kept spinning. We've washed some loads. It works OK but the motor seems to run hot. I've never actually witnessed the motor when it runs so I don't know how hot is should get. Please advise and thanks for help.
#6 Posted : Saturday, January 26, 2008 3:59:21 PM(UTC)
Hot motor means: it was overloaded or the motor itself is bad.
In your case most likely the problem caused by the motor itself and it has to be replaced.
- The part number for the motor is AP3873831
Guest (4)
Maytag Legacy top load washer not spinning (Washer Repair)
by Guest 10/28/2023 8:56:04 AM(UTC)
Whirlpool washer Not spinning 6/21/23 (Washer Repair)
by yveron 6/21/2023 11:33:50 AM(UTC)
Whirlpool WTW4800BQ0 Washer Not Spinning (Washer Repair)
by MrTryToFixIt 12/1/2022 8:20:20 AM(UTC)
frigidaire washer not spinning out clothes (Washer Repair)
by tadthebass 3/24/2020 8:51:55 AM(UTC)
MAYTAG MHWC7500Y WASHER NOT SPINNING AT HIGH SPEED (Washer Repair)
by ehbrown1 11/5/2019 4:50:11 AM(UTC)
Stacked Maytag/Neptune Washer not spinning (Washer Repair)
by Building and Grounds 10/24/2017 12:26:37 PM(UTC)
GE Profile washer not spinning (Washer Repair)
by LSUStephen 7/16/2017 1:25:43 PM(UTC)
Whirlpool washer not spinning fast (Washer Repair)
by AmyM269 9/3/2016 4:22:47 PM(UTC)
Maytag Washer not spinning / draining (Washer Repair)
by retho78 5/21/2016 5:29:56 AM(UTC)
GE Washer not spinning (Washer Repair)
by zoobteach 8/29/2015 10:12:50 AM(UTC)
by atomicsynth 6/2/2015 10:36:31 PM(UTC)
Kenmore 70 Series washer not spinning (Washer Repair)
by workingdad 2/21/2015 7:31:47 PM(UTC)
Whirlpool washer not spinning or agitating; blowing breaker (Washer Repair)
by ejditz3 8/4/2014 1:15:39 PM(UTC)
GE washer not spinning any cycle (Washer Repair)
by j409 6/2/2014 7:44:19 AM(UTC)
Washer not spinning after replacing Thrust Bearing Kit (Washer Repair)
by Woody Williams 2/25/2014 2:06:33 PM(UTC)
