2 Pages12>
Budr
#1 Posted : Friday, September 4, 2009 3:59:58 AM(UTC)
Budr
I have the same problem as everyone else. Replaced all components on back of dryer. tested everything still no heat? Help please!
Frank / APP Team
#2 Posted : Friday, September 4, 2009 6:00:26 AM(UTC)
Frank / APP Team
The model number provided isn't complete so I couldn't take a quick peek to see what you've got, but here's some basics.
Are you sure you've got 240v to the unit? Just because the unit runs doesn't mean you're getting 240. The motor runs off of 120V. Check your house breakers.
Do you have a meter to do some testing? If yes, are you getting 240v to the terminal block where the cord attaches? Where are/aren't you getting power?
By saying all parts on the back, what all did that consist of? Element, thermostats, etc.?
Budr
#3 Posted : Friday, September 4, 2009 6:06:30 AM(UTC)
Budr
Yes, I have 240 at the terminals at the dryer. Replace, themos, element. Dryer runs no heat.
Frank / APP Team
#4 Posted : Friday, September 4, 2009 6:49:51 AM(UTC)
Frank / APP Team
Motor switch comes into play. But considering I couldn't find the model # you've listed anywhere, I couldn't come up with a wiring diagram. If the diagram is on the unit still, you'll need to look at the motor section. You'll see there is a contact on the motor switch which has to close when the motor starts which completes the circuit to the element.
Budr
#5 Posted : Friday, September 4, 2009 7:01:50 AM(UTC)
Budr
Sorry about the model number here it is 11066512694
Frank / APP Team
#6 Posted : Friday, September 4, 2009 9:35:04 AM(UTC)
Frank / APP Team
Afraid I'm striking out trying to find a wiring diagram. Did you also change the thermostat on the blower housing?
Budr
#7 Posted : Friday, September 4, 2009 9:40:12 AM(UTC)
Budr
yes changed out. drum spins just no heat
Frank / APP Team
#8 Posted : Friday, September 4, 2009 9:48:25 AM(UTC)
Frank / APP Team
Well your down to the start switch on the motor or possibly a bad contact in the timer. Without a diagram I've pretty much exhausted all I can do. Maybe someone else will chime in who can come up with a diagram.
Budr
#9 Posted : Friday, September 4, 2009 9:49:18 AM(UTC)
Budr
Wanted to know if the resistor PN#AP3094277 wouls cause dryer not to heat
Frank / APP Team
#10 Posted : Friday, September 4, 2009 9:57:36 AM(UTC)
Frank / APP Team
If memory serves me right, the resistor had to do with the timer advancing, not the heater circuit.
GE Dryer Not Heating - Model: GFDS140ED0WW (Dryer Repair)
by laflair13 3/1/2023 3:14:27 AM(UTC)
Frigidaire Dryer Not Heating - Still Tumbles (Dryer Repair)
by dryerhelp98765 9/18/2021 8:06:29 AM(UTC)
help with samsung dryer not heating : DV350AEW / XAA (Dryer Repair)
by Guest 3/18/2021 11:11:18 AM(UTC)
Kenmore 70 series gas dryer not heating (Dryer Repair)
by Gilmo211 12/29/2020 10:09:04 AM(UTC)
GE Dryer not heating up (Dryer Repair)
by Dryernoob 4/23/2020 10:55:51 AM(UTC)
Dryer Not Heating even tough Fuse and Heating Element is good (Dryer Repair)
by Mixter7958 3/17/2020 4:37:28 PM(UTC)
Dryer not heating, question about voltage drop. (Dryer Repair)
by Pmp816 2/3/2019 6:58:39 AM(UTC)
Amana dryer not heating (Dryer Repair)
by keepingwiththetimes 2/7/2018 2:53:54 PM(UTC)
Whirlpool dryer not heating (Dryer Repair)
by Oscarwray 9/29/2017 4:54:27 PM(UTC)
Maytagdryer Not heating (Dryer Repair)
by ApplianceRN 9/16/2017 12:48:37 PM(UTC)
Dryer not heating (Dryer Repair)
by hoymanj 8/3/2017 2:39:08 PM(UTC)
Maytag Dryer not heating with rattle noise (Dryer Repair)
by Glengc1 6/24/2017 4:09:37 PM(UTC)
Maytag dryer not heating (Dryer Repair)
by Jmr721 4/29/2017 12:11:59 PM(UTC)
Amana Dryer not heating (Dryer Repair)
by HnRmom 4/27/2017 6:09:54 PM(UTC)
by tcdegener@yahoo.com 11/10/2016 8:39:58 AM(UTC)
2 Pages12>
