Ricky50
#1 Posted : Wednesday, August 19, 2009 7:15:58 PM(UTC)
Ricky50
In the beginning my dryer stayed HOT and I had to replace the thermostat once, everything worked fine for about 9 months, now it did the same thing and I again Replaced the hi limited thermostat again but now My dryer now stops on me after 2 minutes of running. I have changed the HiLimiter thermostat. With the top off, I can see the heating element coming on and going off which seems ok but the problem is now that it stops running ater about 2 to 3 minutes of running and the front lights blink and beep at the same time. I cleaned everything, lint free, vents cleaned even put a big blower in the exhaust vent going outside to make sure that is not plug, everything ok there also. Also when the machine is OFF the lights will come on and blink and beep. Is there a CODE RESET I have to do to stop these lights from flashing and beeping? Please, anyone help
Rick
sidfink43
#2 Posted : Thursday, August 20, 2009 4:02:17 PM(UTC)
sidfink43
Those blinking lights are error codes. You need to look inside the dryer, either in the service panel in back or the bottom panel in front and find the tech sheet. It will tell you how to troubleshoot your machine and what the error code are.
Good luck.
Ricky50
#3 Posted : Thursday, August 20, 2009 4:07:08 PM(UTC)
Ricky50
Thank you very much, I do remember seeing that Tech Sheet at the bottom of the dryer in the Front area. Will let you know what happens, Thanks again
Rick
Ricky50
#4 Posted : Saturday, August 22, 2009 9:48:39 AM(UTC)
Ricky50
I did what you told me and everything in the TEST area worked out perfect, but in the ERROR CODE area, I Get 6 blinks on the four LCD lights and 2 blinks on the Start LCD which means that the error code is: 62. but in the manual it does not say anything about Code 62, The only thing close to that code is 68 in the manual but no 62???? Do you know what 62 is? And what the problem could be. Thank you for your time and concern.
Ricky
sidfink43
#5 Posted : Saturday, August 22, 2009 12:44:39 PM(UTC)
sidfink43
No, I do not see a code E62, and I doubt you have an E68 problems.
The best guess is that you have a main control board failure, but unfortuntely the only way to be certain is to replace the board and see if that fixes it, and that is an expensive item.
Also, in case you did not know, the only thing GE about your machine is the GE logo on it. It is Frigidaire Gallery Dryer.
If you decide to replace the main board, let us know how it turns out.
Good luck.
Ricky50
#6 Posted : Sunday, August 23, 2009 4:19:16 PM(UTC)
Ricky50
If the Control Board would be bad, would it still have given me all the 1 to 6 Diagnostic test results perfect with each one doing what it should do? Doesn't this work off the control Board? That's a lot of money to spend just to see if it's that. Could it be a BAD Circuit breaker on the motor shutting it up like that after 30 seconds of running? Thank you for your time on this. I really don't know where to go from here..... I rather just go and buy a New Dryer and get a 10 Year warranty with it and be done of it. I Only had these machine for one and half year and already TWO THermostat's and now this....
sidfink43
#7 Posted : Sunday, August 23, 2009 4:47:58 PM(UTC)
sidfink43
I sympathize with your plight, this is the world of micro processor controls where you cannot get any good reliable diagnosis. If you call a tech to your site he or she will diagnose the problem by replacing the board. If it fixes it, that was the problem. If it does not, then it was not the problem.
You can have a motor failure, but I do not believe there is any switch or relay on the motor that is causing this. I suggested a board failure because the troubleshooting showed an error code that does not exist.
About all the I can do for you now is provide you with a copy of the service manual. Here it is.
http://frigidaireservicetips.co...rGoodandBetterModels.pdf
If you decide to replace the machine a basic no frills dryer with mechanical controls will do a fine job for you.
Good luck, sorry not to be more definitive but that's the microprocessor world we live in.
nuclearr
#8 Posted : Wednesday, May 2, 2012 3:29:46 PM(UTC)
nuclearr
I was having the same error code as OP I replaced the control board it fixed my dryer.
Guest (4)
Kenmore Dryer stops running after start button is released (Dryer Repair)
by Jbee14 7/30/2023 11:15:53 AM(UTC)
Dryer stops running when I release the push to start button (Dryer Repair)
by Guest 6/22/2022 9:57:15 AM(UTC)
Dryer stops running after 20 min on heated cycle (Dryer Repair)
by Olaf_sc 11/2/2015 9:05:28 AM(UTC)
Frigidaire dryer stops running (Dryer Repair)
by Fritzfarm 12/22/2011 9:03:34 AM(UTC)
Dryer stops running after a while (Dryer Repair)
by darcher007 1/16/2011 3:05:41 PM(UTC)
by pstulken 12/22/2010 2:47:11 PM(UTC)
Dryer stops running after 10minutes (Dryer Repair)
by Jimmyz2011 12/20/2010 12:35:26 PM(UTC)
dryer stops running after 20 seconds (Dryer Repair)
by Glen Hoh 10/14/2010 6:30:33 AM(UTC)
Dryer stops running before timer cycle ends (Dryer Repair)
by fascamaro 2/6/2010 3:56:45 AM(UTC)
by RobinAlice 9/20/2009 7:47:35 AM(UTC)
Dryer stops running on heat settings (Dryer Repair)
by tld61672 4/12/2009 4:30:39 AM(UTC)
Roper dryer stops running (Dryer Repair)
by NcTarHeel704 3/1/2009 9:51:11 AM(UTC)
Dryer stops running (Dryer Repair)
by den123 11/9/2008 6:50:33 AM(UTC)
Dryer stops running after letting off the Start button (Dryer Repair)
by Andy 7/27/2007 8:13:13 AM(UTC)
