den123
#1 Posted : Sunday, November 9, 2008 6:50:33 AM(UTC)
den123
This dryer will just stop turning after awhile. If you open it up and manually turn the drum and restart it, it will take off. Repair people came out to look at it and with out even looking said the motor is overheating and we need a new motor. Does this sound right?
kayakcrzy
#2 Posted : Monday, November 10, 2008 4:16:36 AM(UTC)
kayakcrzy
Yes, they are right on the money. Tom ApplianceEducator.com
Kenmore Dryer stops running after start button is released (Dryer Repair)
by Jbee14 7/30/2023 11:15:53 AM(UTC)
Dryer stops running when I release the push to start button (Dryer Repair)
by Guest 6/22/2022 9:57:15 AM(UTC)
Dryer stops running after 20 min on heated cycle (Dryer Repair)
by Olaf_sc 11/2/2015 9:05:28 AM(UTC)
Frigidaire dryer stops running (Dryer Repair)
by Fritzfarm 12/22/2011 9:03:34 AM(UTC)
Dryer stops running after a while (Dryer Repair)
by darcher007 1/16/2011 3:05:41 PM(UTC)
by pstulken 12/22/2010 2:47:11 PM(UTC)
Dryer stops running after 10minutes (Dryer Repair)
by Jimmyz2011 12/20/2010 12:35:26 PM(UTC)
dryer stops running after 20 seconds (Dryer Repair)
by Glen Hoh 10/14/2010 6:30:33 AM(UTC)
Dryer stops running before timer cycle ends (Dryer Repair)
by fascamaro 2/6/2010 3:56:45 AM(UTC)
by RobinAlice 9/20/2009 7:47:35 AM(UTC)
Dryer stops running (Dryer Repair)
by Ricky50 8/19/2009 7:15:58 PM(UTC)
Dryer stops running on heat settings (Dryer Repair)
by tld61672 4/12/2009 4:30:39 AM(UTC)
Roper dryer stops running (Dryer Repair)
by NcTarHeel704 3/1/2009 9:51:11 AM(UTC)
Dryer stops running after letting off the Start button (Dryer Repair)
by Andy 7/27/2007 8:13:13 AM(UTC)
