pstulken
#1 Posted : Wednesday, December 22, 2010 2:47:11 PM(UTC)
pstulken
What could cause the dryer to stop when the load of wet clothes is too heavy for the drum to turn. For example-I load the dryer with wet clothes. If the size of the load is too heavy, the dryer stops. I'll take some clothes out and restart...which it does and the dryer will finish its cycle.
#2 Posted : Wednesday, December 22, 2010 6:21:04 PM(UTC)
Most likely the problem is a bad motor.
- The motor Part number: AP3094245
Kenmore Dryer stops running after start button is released (Dryer Repair)
by Jbee14 7/30/2023 11:15:53 AM(UTC)
Dryer stops running when I release the push to start button (Dryer Repair)
by Guest 6/22/2022 9:57:15 AM(UTC)
Dryer stops running after 20 min on heated cycle (Dryer Repair)
by Olaf_sc 11/2/2015 9:05:28 AM(UTC)
Frigidaire dryer stops running (Dryer Repair)
by Fritzfarm 12/22/2011 9:03:34 AM(UTC)
Dryer stops running after a while (Dryer Repair)
by darcher007 1/16/2011 3:05:41 PM(UTC)
Dryer stops running after 10minutes (Dryer Repair)
by Jimmyz2011 12/20/2010 12:35:26 PM(UTC)
dryer stops running after 20 seconds (Dryer Repair)
by Glen Hoh 10/14/2010 6:30:33 AM(UTC)
Dryer stops running before timer cycle ends (Dryer Repair)
by fascamaro 2/6/2010 3:56:45 AM(UTC)
by RobinAlice 9/20/2009 7:47:35 AM(UTC)
Dryer stops running (Dryer Repair)
by Ricky50 8/19/2009 7:15:58 PM(UTC)
Dryer stops running on heat settings (Dryer Repair)
by tld61672 4/12/2009 4:30:39 AM(UTC)
Roper dryer stops running (Dryer Repair)
by NcTarHeel704 3/1/2009 9:51:11 AM(UTC)
by den123 11/9/2008 6:50:33 AM(UTC)
Dryer stops running after letting off the Start button (Dryer Repair)
by Andy 7/27/2007 8:13:13 AM(UTC)
