I starting the dryer and it starts to heat and run fine, but after about 20 seconds it shuts off. I wait a while and restart and get the same result.
Originally Posted by: Glen Hoh  I starting the dryer and it starts to heat and run fine, but after about 20 seconds it shuts off. I wait a while and restart and get the same result. Glen, Sounds like an overheating motor, Part number: AP4029141
you may want to replace the drum belt, as well, Part number: AP4049271
You will also need to check and clean the exhaust, and venting for holes and loose fitting parts. (that's what usually causes the problem, lint in or on the motor). Good Luck, :) :) :)
