2 Pages12>
theltzel
#1 Posted : 17 years ago
theltzel
I have a whirlpool estate gas dryer that will not heat. i have replaced the ignitor but that did not help. Any suggestions on what to try next.
#2 Posted : 17 years ago
Pull the dryer of the wall, unplug the power cord, remove the vent hose from the dryer and remove the back panel.
According to the bulkhead parts break down diagram start the troubleshooting from the thermal fuse (#7). Remove at least one wire from the thermal fuse and check the continuity across terminals.
If the thermal fuse is open it has to be replaced together with the cycling thermostat (#9).
If this is not an issue, go to the flame sensor(#49) and perform the same continuity test. Replace if it's open.
- The part number for the thermal fuse AP3132867
- The part number for the cycling thermostat AP3131939
- The part number for the flame sensor is AP2910747
- Here are the break down diagrams for the Whirlpool Estate dryer Model TGDS840JQ0
Good luck and Happy New year.
dpyat
#3 Posted : 16 years ago
dpyat
Gene,
My dryer problem is: it ignites the gas , then within 2 min flame its shuts off (some heat are observed), the motor is still working, after min or two the igniter starts again , BUT then shut off without igniting the gas
I did replaces
thermal fuse (#7) together with the cycling thermostat (#9) and flame sensor(#49) .
And it did not help me. Same result.
Please advise.
#4 Posted : 16 years ago
It did not help because the problem most likely is a bad gas valve coils. If you need the correct part number then post the complete model number of the dryer.
dpyat
#5 Posted : 16 years ago
dpyat
Gene, thanks for you help. My dryer is Whirlpool Estate dryer Model TGDS840JQ0
Are you referring to:[/URL]
main the two terminal coil
AP3041626 $23.75
secondary three terminal coilAP3041625. $23.75
Can I use the kit consisting both coils [URL="http://www.appliancepartspros.com/partsearch/ctrfs.aspx?pn_=AP3094251&&&model_id=264778&diagram_id=114845"]AP3094251 for $14.89 ?
As you can see its a big difference in $$$ between a kit and single coils.
Also, how hard is to disassemble a burner? Thanks for any tips.
#6 Posted : 16 years ago
Originally Posted by: dpyat Go to Quoted Post
...Can I use the kit consisting both coils AP3094251 for $14.89 ?...
Definitely you can.
You do not have to disassemble the burner. Just remove the two screws holding the top mounting bracket and you will gain access to the coils.
dpyat
#7 Posted : 16 years ago
dpyat
Gene, thanks. It worked!
I changed both coils, it was very easy.
Again thank you very much for your help.
David
#8 Posted : 16 years ago
You are welcome David. I'm glad you were able to fix it. Thank you for the feedback and good luck with your dryer.
tbh
#9 Posted : 16 years ago
tbh
Gene,
I have a very similar problem to the one that was just solved here. The igniter seems to work, turning bright red for about 10 seconds, however it does not ignite any gas. I checked all the thermostats, thermal fuse, and flame sensor. All check out for continuity. Would the gas valve coils be the culprit here? I read somewhere that it may be the igniter also, as it may not be heating enough to allow the valves to open???
Thanks for you help
#10 Posted : 16 years ago
Originally Posted by: tbh Go to Quoted Post
Gene,
Thanks for you help
Most likely the problem is a bad gas valve coils. What ever you read about igniter probably was about oven igniter. Oven igniter and dryer igniter work very different. Dryer igniter usually has only two stages: glow or not.
New Kenmore Elite 796 Gas Dryer Won't Heat (Dryer Repair)
by Guest 2 years ago
Whirlpool Duet Dryer won't heat anymore (Dryer Repair)
by Guest 4 years ago
Dryer won't heat consistently – Is an RCA model dryer actually GE? (Dryer Repair)
by OpsTao 4 years ago
Samsung Dryer Won't heat no matter what I do (Dryer Repair)
by coachroy 4 years ago
Whirlpool LGT7848AQ1 dryer won't heat (Dryer Repair)
by spiggman 4 years ago
Kenmore Electric Dryer Won't Heat (Dryer Repair)
by ginakra 7 years ago
Dryer won't heat (Dryer Repair)
by ncoles6 8 years ago
Whirlpool Dryer won't heat (Dryer Repair)
by spelding 8 years ago
by Kate123 9 years ago
Stumped - Samsung Dryer Won't Heat (Dryer Repair)
by TankusKC 9 years ago
by haymon 9 years ago
by wgomezp1 9 years ago
by chash 10 years ago
Gas dryer won't heat (Dryer Repair)
by pino2424 10 years ago
A different my dryer won't heat problem (Dryer Repair)
by mikeysotp 10 years ago
2 Pages12>
