banluc
#1 Posted : 18 years ago
banluc
I checked the water supply down at the connection to the refrigerator/valve and is all clean. What should I check next, before ordering the whole new ice maker? Is there a disassembly manual or website with it? I know some parts are plastic snap-on,anddon't weant damage any of them...
#2 Posted : 18 years ago
banluc
The first thing I would check is if the ice maker is "on" or "off". Check the position of the ice maker arm - it should be pushed down. If it's up then the ice maker is "off".
If this is not the issue then check the coil on the water valve for continuity. The water valve is located on the back of the fridge. Also check the ice maker fill tube - it could be frozen up. If there is no continuity on the coil or the fill tube is frozen up - the water valve has to be replaced. The part number for the new water valve is AP2583509
If all of the above is fine then the ice maker has to be replaced. The part number for the new ice maker is AP3160597
Good luck.
brdancer
#3 Posted : 18 years ago
brdancer
I have GE side by side...model number TPS24PPBE BS...The unit is about 8 years old. I have removed both water valves and plan to replace them. I am confused as to why there are two separate water valves...I have a water dispenser in the door, and the ice maker as well as an inline filter. What do all these valves do? There were about 5 or 6 water lines leading into or from the two valves.
This evening (after removing the two valves this am) I noticed some water leakage around the bottom of the front door on the freezer side. Also, items in the freezer appeared to be thawing though freezer is cold and appeared to be working properly? I have not replaced the two valve assemblies yet as I obtained one locally but the other will not be available until Thursday. So, I planned to wait and install both at the same time.
Help.
Whirlpool Model WRS588FIHZ00 Ice Maker Stopped Working (Refrigerator & Freezer Repair)
by roma1625 3 years ago
GE Ice Maker Stopped Working (Refrigerator & Freezer Repair)
by Jyet2001 9 years ago
Ice maker stopped working... (Refrigerator & Freezer Repair)
by Steelwheels1 10 years ago
Ice maker stopped working on Kitchenaid (Refrigerator & Freezer Repair)
by schroederius 12 years ago
by ACHASG 13 years ago
Ice maker stopped working (Refrigerator & Freezer Repair)
by Cindy Schneider 13 years ago
by wrexpert 14 years ago
Control Panel, Ice Maker Stopped Working (Refrigerator & Freezer Repair)
by jrymski 14 years ago
Ice maker stopped working. (Refrigerator & Freezer Repair)
by HomerH209 14 years ago
Amana Ice Maker Stopped Working (Refrigerator & Freezer Repair)
by smaggard 15 years ago
Maytag French Door ice maker stopped working (Refrigerator & Freezer Repair)
by kayken1010 15 years ago
by dmkimm 15 years ago
Kitchenaid side by side ice maker stopped working (Refrigerator & Freezer Repair)
by aloubo 15 years ago
ice maker stopped working - kenmore elite side by side (Refrigerator & Freezer Repair)
by foobydoo 15 years ago
GE Adora Fridge: Ice Maker stopped working. (Refrigerator & Freezer Repair)
by lighthouse832 15 years ago
