hee@hardinnet.com
#1 Posted : Friday, January 11, 2008 9:53:44 AM(UTC)
hee@hardinnet.com
Igniter lites but oven will not lite.
1.120v going into thermostat
2.120v coming out of thermostat
3.2.4v at gas valve
4.Gas valve says not to put 120v to it.
5.Gas valve rated 3.0-3.3v
Wiring diag.does not show a resistor,unless its in the wire.
So any help would be greatly apprecaited.
Also how important are the gaskets under the top sealed burners?I have 2 that have disintegrated.
After looking a little further.apparently the wiring goes thru the igniter to reduce the voltage to the gas valve.when the ingniter is on ,the top bar glows white and the lower part glows red.If I read an other post on here it should be glowing white all over.Could there be a crack that I can't see be causing the voltage to drop to the gas valve.Or is the igniter just not getting hot enough to turn the gas on? Using a meter I got a reading of 196 ohms resitance on the igniter which does'nt help me because I don't know what its supposed to be.
Thanks in advance
hee@hardinnet.com
#2 Posted : Saturday, January 12, 2008 2:43:18 PM(UTC)
hee@hardinnet.com
Fixed it my self local dealer had an igniter and now its working again.
Guest (4)
KitchenAid KERC506HWH3 no oven heat (Oven Repair (including Ranges and Cooktops))
by luckyatva 1/23/2016 2:29:45 PM(UTC)
Top burners work but no oven, broil, or display (Oven Repair (including Ranges and Cooktops))
by rossmarp 12/5/2013 4:20:51 PM(UTC)
Whirlpool SF362LXSQ0 - No oven/broiler functionality (Oven Repair (including Ranges and Cooktops))
by zachsr 8/7/2013 6:49:29 AM(UTC)
No oven heat - frigidaire GLEFM397dsa (Oven Repair (including Ranges and Cooktops))
by sptophat 10/23/2012 11:04:42 AM(UTC)
No Oven/Surface (Oven Repair (including Ranges and Cooktops))
by not_sure 4/7/2012 8:19:31 AM(UTC)
no oven new control board (Oven Repair (including Ranges and Cooktops))
by rlcjmrdr 1/10/2012 3:18:02 PM(UTC)
Replaced bake element. Still no oven (Oven Repair (including Ranges and Cooktops))
by ScottZ 10/27/2011 9:49:51 AM(UTC)
No digital display therefore no oven but stove top works. (Oven Repair (including Ranges and Cooktops))
by indymom92 7/7/2011 12:14:39 PM(UTC)
Kenmore Range - no oven - no error - clock, lights & range ok (Oven Repair (including Ranges and Cooktops))
by jfilanoski 4/28/2011 8:44:42 AM(UTC)
igniters glow but no oven or broiler gas (Oven Repair (including Ranges and Cooktops))
by Ron_H 5/27/2010 1:47:59 PM(UTC)
Replaced main board and still no oven. (Oven Repair (including Ranges and Cooktops))
by Garfield69 4/27/2010 2:25:50 PM(UTC)
No oven start (Oven Repair (including Ranges and Cooktops))
by drewbp 4/5/2010 8:20:42 PM(UTC)
I have no oven (Oven Repair (including Ranges and Cooktops))
by skeezic3 8/27/2009 8:13:03 AM(UTC)
broiler and igniters work no oven? (Oven Repair (including Ranges and Cooktops))
by conmom 7/15/2009 12:49:18 PM(UTC)
Oven Fan constant Run no oven burner (Oven Repair (including Ranges and Cooktops))
by Bob LLWC 6/3/2009 8:43:32 AM(UTC)
