My range just up and quit. Not sure where to start on the troubleshooting.
Clock, display buttons etc. seem to work fine.
It's a smooth top. We were using the surface at the time it stopped. Now no lights indicating a burner is on and no heat on surface.
If I turn on the oven, it allows me to set the temp and preheat light comes on, but no heat through the element.
I have turned off the breaker and turned back on (CTL-ALT-DEL), no help.
Any suggestions would be awesome. I'm not afraid to dig into it, but not really sure where and have no good documentation.
TIA
Turned out to be the outlet. One of the hot legs had a bad connection so the control board got 110, but the 240 wasn't there for operating stove top or oven.
