zachsr
#1 Posted : Wednesday, August 7, 2013 6:49:29 AM(UTC)
zachsr
Hello,
I have searched and found some threads on this specific issue of my oven and broiler not working at all and found some recommendations on how to check but being a total newbie, I had a quick question. When I am testing the continuity on the gas regulator (after unplugging the three wires) am I placing the multi-meter on the actual regulator diodes to test? or the disconnected wires themselves? I have done a couple of checks. I placed the multimeter on the regulator with wires disconnected - common to broil gave me a zero reading and common to bake also gave me a zero reading. When i placed the multimeter on the wires themselves, I get about 220 resistance reading on both bake and broil. Is my regulator bad? I also placed the multimeter on the DSI board to check J1-1 and J1-4 to see if I get any readings after I hit the bake button - only noticed that the multimeter jumped just a little but never hit the 120 that I read about.
Anyone out there available to provide some guidance?
Thank you
sika25
#2 Posted : Wednesday, August 7, 2013 8:45:33 AM(UTC)
sika25
I have the same problem. The repair company I called are convinced it is the thermal fuse and will not come test the appliance until they have got the fuse in stock. I am confused as I haven't read any other posts suggesting this as an issue unless things fail after a self-cleaning cycle (which I hadn't done).
zachsr
#3 Posted : Tuesday, September 3, 2013 12:41:44 PM(UTC)
zachsr
Any experts out there willing to assist?
Thank you :)
zachsr
#4 Posted : Monday, September 30, 2013 6:14:02 PM(UTC)
zachsr
So I was able to get my oven and broiler working again by replacing the gas valve unit I purchased from appliancepartspros. Hope this anyone else out there with this issue.
