Hello, I have searched and found some threads on this specific issue of my oven and broiler not working at all and found some recommendations on how to check but being a total newbie, I had a quick question. When I am testing the continuity on the gas regulator (after unplugging the three wires) am I placing the multi-meter on the actual regulator diodes to test? or the disconnected wires themselves? I have done a couple of checks. I placed the multimeter on the regulator with wires disconnected - common to broil gave me a zero reading and common to bake also gave me a zero reading. When i placed the multimeter on the wires themselves, I get about 220 resistance reading on both bake and broil. Is my regulator bad? I also placed the multimeter on the DSI board to check J1-1 and J1-4 to see if I get any readings after I hit the bake button - only noticed that the multimeter jumped just a little but never hit the 120 that I read about. Anyone out there available to provide some guidance?
Thank you
I have the same problem. The repair company I called are convinced it is the thermal fuse and will not come test the appliance until they have got the fuse in stock. I am confused as I haven't read any other posts suggesting this as an issue unless things fail after a self-cleaning cycle (which I hadn't done).
Any experts out there willing to assist? Thank you :)
So I was able to get my oven and broiler working again by replacing the gas valve unit I purchased from appliancepartspros. Hope this anyone else out there with this issue.
