#1 Posted : Friday, July 31, 2009 4:16:21 AM(UTC)
Customer overloaded the washer with towels, motor LED flashed nine times.
Diagnostics say brake resistor failed. Customer did the clear error code procedure.
I checked web site HydroWave GE Washer Repair Guide. At that site, they say to replace the motor. Is this necessary, the washer now spins up to speed?
applianceman
#2 Posted : Friday, July 31, 2009 8:52:26 AM(UTC)
applianceman
Only if the code returns.
applianceman
#3 Posted : Friday, July 31, 2009 8:56:33 AM(UTC)
applianceman
For whatever reason these codes seem to come up for no reason. I called GE tech support and they said only replace the motor if the code returns.
#4 Posted : Friday, July 31, 2009 10:02:17 AM(UTC)
Thanks for the info, new to fixing these washers.
applianceman
#5 Posted : Friday, July 31, 2009 1:52:36 PM(UTC)
applianceman
Anytime! A note has been added to the bottom of that page addressing that issue.
GE Hydrowave Washer Motor Hot Code (Washer Repair)
by Terry B 4/26/2020 11:13:26 AM(UTC)
GE Hydrowave Washer control panel reset? problem (Washer Repair)
by janiew48 3/9/2019 8:34:15 AM(UTC)
GE Hydrowave Washer Help (Washer Repair)
by Ae3734 1/13/2017 7:59:44 AM(UTC)
GE Hydrowave Washer won't spin (Washer Repair)
by Lakelander 10/30/2015 9:47:08 AM(UTC)
GE hydrowave washer on the fritz (Washer Repair)
by Robinwyman 10/7/2015 9:18:51 AM(UTC)
GE Hydrowave washer sagging apron? (Washer Repair)
by Robgeneb 8/17/2015 12:47:42 PM(UTC)
GE Hydrowave washer won't spin or agitate (Washer Repair)
by lilajfischer 8/7/2014 3:20:38 PM(UTC)
Removal of GE Hydrowave washer agitator (Washer Repair)
by Dave Storck 3/30/2014 11:18:01 AM(UTC)
GE Hydrowave Washer won't spin or agitate (Washer Repair)
by budmanluvtofish 1/15/2013 4:02:27 AM(UTC)
GE hydrowave washer wont spin (Washer Repair)
by dgjr 6/19/2012 1:33:10 AM(UTC)
GE Hydrowave washer won't agitate (Washer Repair)
by gaotu49 10/12/2011 8:06:48 AM(UTC)
GE hydrowave washer repair--lesson learned (Washer Repair)
by Narapni 2/22/2011 1:22:54 AM(UTC)
GE hydrowave washer (Washer Repair)
by itwist1 5/27/2010 5:11:51 AM(UTC)
