I read a few post of the same problem, but thought I would ask anyways. I do not know the age as I bought the home with it already here. Oven trys to ignite (sparks 5 or so time) and then shuts off gas. I do smell some gas. Cook top and broiler work, but no oven. The gas company worked on meter this week, but used the oven once after and it was fine. Is it possible that it got dirty and caused this problem. From your parts list I see a Part Number: AP3598752? Should I replace it or is it cleanable? Thank you for your help!
