bruce2
#1 Posted : Saturday, July 11, 2009 2:14:46 PM(UTC)
bruce2
no water being delivered to ice maker----replaced filter and water valve---still no water at ice maker. what's next?
woodchuckie
#2 Posted : Saturday, July 11, 2009 3:35:15 PM(UTC)
woodchuckie
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
GE bottom freezer model #: PFE28KBLTS not cooling well and no ice (Refrigerator & Freezer Repair)
by Danny1976 6/7/2024 12:43:43 PM(UTC)
GE bottom freezer not cooling well and no ice (Refrigerator & Freezer Repair)
by Guest 6/7/2024 7:31:51 AM(UTC)
problem with no ice in bottom ice maker (Refrigerator & Freezer Repair)
by Daver032 11/29/2023 6:13:20 AM(UTC)
Maytag Frige 2014 no Ice & frige is 50 degrees (Refrigerator & Freezer Repair)
by Plus160 7/5/2023 5:05:07 PM(UTC)
No Ice No Water on LG LFX21960ST Refrig (Refrigerator & Freezer Repair)
by jvc57 3/3/2023 4:42:12 AM(UTC)
GE Cafe Refrigerator No Ice (Refrigerator & Freezer Repair)
by amappliancewi 2/8/2023 5:22:22 PM(UTC)
GE Fridge - no ice (Refrigerator & Freezer Repair)
by Guest 1/22/2023 8:39:51 AM(UTC)
Kitchen Aid 5 door - no ice (Refrigerator & Freezer Repair)
by charleskelleriv 10/31/2022 6:13:54 AM(UTC)
Whirlpool wrx735sdbe00 - Fridge warm no ice (Refrigerator & Freezer Repair)
by old_school33 6/10/2022 2:29:09 PM(UTC)
No Icecream at night - Freezer stops cooling around 8PM and everything is Frozen by 8AM. - (Refrigerator & Freezer Repair)
by usercraig 3/7/2022 7:40:11 PM(UTC)
Whirlpool Ice maker problems - no ice (Refrigerator & Freezer Repair)
by mphillips9im 7/17/2021 11:48:06 AM(UTC)
Replaced water inlet valve, still no ice or water (Refrigerator & Freezer Repair)
by Guest 7/3/2021 3:14:08 PM(UTC)
Samsung RS265TDRS Not Cooling/No Ice (Refrigerator & Freezer Repair)
by Guest 5/31/2021 10:09:58 AM(UTC)
GE Fridge model CFSP5RKBBSS - No Icecubes (Refrigerator & Freezer Repair)
by HaroldS 2/13/2021 2:17:30 PM(UTC)
** RESOLVED ** Subzero 590, no ice (Refrigerator & Freezer Repair)
by Intel1919 9/12/2020 9:54:24 AM(UTC)
