ompong
#1 Posted : Monday, June 16, 2008 7:12:02 AM(UTC)
ompong
gas dryer runs/tumbles but no heat. opened front panel, ignitor does not become hot. checked resistance 78 ohms. checked flame sensor continuity-ok. checked continuity on duct limit thermostat-ok. checked thermostat (3 terminals) 1-2 continuity-ok but 1-3-open. checked the thermostat heater underneath it-also open. does that mean that i needed to replace thermostat & thermostat heater? thank you in advance for your help, ompong
#2 Posted : Tuesday, June 17, 2008 10:15:55 AM(UTC)
Measure the gas valve coils resistance. It suppose to be: across the terminals on the left side coil (on the picture) - 1220 Ohms ± 50, across the left and middle terminals on the right side coil - 1365 Ohms ± 25, across the right and left terminals on the right side coil - 560 Ohms ± 25.
If any of the readings is wrong then replace both coils.
- The part number for the coil kit is AP2150379
UserPostedImage
ompong
#3 Posted : Wednesday, June 18, 2008 5:49:02 AM(UTC)
ompong
i checked the coils, the one with two terminals- open; the other's measurement is just like what you said it would be. ordered parts, will let you know. thank you so much for your quick response, ompong
ompong
#4 Posted : Friday, June 20, 2008 5:41:18 PM(UTC)
ompong
hi Gene, i got it to work!!! thank you so much for all your help, ompong
#5 Posted : Friday, June 20, 2008 5:48:40 PM(UTC)
You are welcome.
becca
#6 Posted : Thursday, July 9, 2009 2:10:27 PM(UTC)
becca
Measure the gas valve coils resistance. It suppose to be: across the terminals on the left side coil (on the picture) - 1220 Ohms ± 50, across the left and middle terminals on the right side coil - 1365 Ohms ± 25, across the right and middle terminals on the right side coil - 560 Ohms ± 25.
UserPostedImage
what do u mean measure with what kind of tool? i feel really dumb asking these questions but my dryer wont heat either and it will run all day untill i open the door.
#7 Posted : Thursday, July 9, 2009 7:38:22 PM(UTC)
What is the complete model number of the dryer?
becca
#8 Posted : Saturday, July 11, 2009 7:55:43 AM(UTC)
becca
its a whirlpool model number LGR6620pto gas dryer
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
Dryer runs but no heat. (Dryer Repair)
by Elarde 6/18/2015 1:17:00 AM(UTC)
Electric dryer runs but no heat (Dryer Repair)
by M hatcher 1/28/2015 2:49:23 PM(UTC)
new kenmore dryer runs but no heat (Dryer Repair)
by crazyhouse 11/19/2012 4:56:14 PM(UTC)
GE gas dryer runs but no heat. (Dryer Repair)
by rroy58 11/19/2012 3:07:23 PM(UTC)
Dryer runs but no heat (Dryer Repair)
by barglancy 9/26/2011 4:44:08 PM(UTC)
another "dryer runs but no heat" problem (Dryer Repair)
by Rayman812 6/27/2011 7:31:38 PM(UTC)
Whirlpool Gas Dryer Runs But No Heat (Dryer Repair)
by cybolt 3/10/2011 8:08:45 PM(UTC)
by sdean 2/8/2011 2:05:25 PM(UTC)
Gas dryer runs but no heat (Dryer Repair)
by pastrychef 1/31/2011 9:02:20 PM(UTC)
Gas dryer runs but no heat. (Dryer Repair)
by peter g 1/7/2011 9:32:32 PM(UTC)
by glenn906 7/1/2010 11:14:54 AM(UTC)
Frigidare gas dryer runs but no heat or ignition (Dryer Repair)
by hanzi1 5/21/2010 12:06:37 PM(UTC)
by katyld 1/27/2010 3:06:34 PM(UTC)
by je24995 12/13/2009 11:19:31 AM(UTC)
