Doc Holiday
#1 Posted : Monday, July 6, 2009 9:12:20 AM(UTC)
Doc Holiday
Dryer was working this weekend with a humming noise. The dryer started on the last load, ran for approximately a minute or two, and then there was a pop. The motor was running but the drum was not turning. Is this a dryer belt problem? Will the belt kit fix the problem? Should I do any other maintenance when I replace the belt on the drum?
#2 Posted : Monday, July 6, 2009 8:09:46 PM(UTC)
Take the dryer apart and inspect the belt. It's a good time to clean the dryer from the lint inside. You would like to replace the drum support rollers and the idler pulley at the same time.
The Service manual.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL LER4434AQ0 | AppliancePartsPros.com
Doc Holiday
#3 Posted : Tuesday, July 7, 2009 7:05:24 AM(UTC)
Doc Holiday
I will look at the belt this evening. I did turn on the dryer to see if it was making the same noise.
This time, the dryer made a clicking sound while the drum was turning. Any other ideas before I inspect the belt?
Thank you.
#4 Posted : Tuesday, July 7, 2009 4:04:49 PM(UTC)
I would inspect all moving parts and the motor.
Doc Holiday
#5 Posted : Wednesday, July 15, 2009 7:16:33 AM(UTC)
Doc Holiday
Gene, I replace the rollers, the idler pulley, and the drum belt as you suggested. Also, I clean out the lent from inside the dryer. Afterwards the dryer ran much smoother and seemed to be much tighter.
I found out what the loud noise was after the initial humming. It was a wrapping from a cleaning sheet that was stuck to the exhaust fan. It must have dropped into the exhaust system one time when the lint screen was removed for cleaning.
Thank you!!
cvcg3499
#6 Posted : Wednesday, July 15, 2009 10:32:19 AM(UTC)
cvcg3499
if the belt is broken change belt, but make sure the motor runs without belt first.
#7 Posted : Wednesday, July 15, 2009 3:42:26 PM(UTC)
You are welcome Doc. I'm glad you were able to fix it. It's a good idea to clean the lint at least every other year.
Maytag gas dryer problem with model MDG5500AWW (Dryer Repair)
by Guest 4/15/2023 1:25:03 PM(UTC)
Front load dryer problem (Dryer Repair)
by Guest 4/29/2021 5:08:47 AM(UTC)
Kenmore dryer problems after replace drum belt/idler pulley (Dryer Repair)
by Hspot 11/22/2020 12:41:02 PM(UTC)
Dryer problem (Dryer Repair)
by johnh@echoetching.com 3/27/2018 12:50:30 PM(UTC)
by al kopsick 10/8/2017 11:08:40 AM(UTC)
Cabrio dryer problems (Dryer Repair)
by artsalena 1/19/2017 2:37:30 PM(UTC)
Dryer Problem (Dryer Repair)
by clcw199 11/5/2015 9:07:48 AM(UTC)
Need help narrowing dryer problem.... (Dryer Repair)
by blkhwks19 10/19/2015 9:06:20 AM(UTC)
by gtravis331 4/13/2014 6:01:38 PM(UTC)
by Qzzy 3/17/2014 8:01:45 PM(UTC)
clothes dryer problem (Dryer Repair)
by jsullivan652 1/28/2014 1:20:49 AM(UTC)
Dryer Problem - Fuse Blowing (Dryer Repair)
by ppp2000 10/22/2013 3:21:12 AM(UTC)
by Pat Ranguette 8/26/2013 5:41:29 PM(UTC)
by forenz 7/2/2013 1:34:33 PM(UTC)
by Hoovdawg3 6/8/2013 3:42:16 PM(UTC)
