John Kilford
#1 Posted : Thursday, May 28, 2009 7:18:08 AM(UTC)
John Kilford
Dryer will not start. Power is geting to the dryer, I have checked external fuses and circuit breakers, when door open light inside drum is on. When timer is set it can be heard running, but, when start button is pushed, nothing happens. Question is what would be the most likely cause?
#2 Posted : Thursday, May 28, 2009 5:09:03 PM(UTC)
The first thing I would do is remove the bottom access panel and check the belt. There is a special "broken belt switch" under the idler pulley which interrupts the power to the motor if the belt brakes.
If there is nothing wrong with the belt and/or the belt switch then I would check the thermal fuse (#59 on the diagram) for continuity.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL GEQ8811KQ0 | AppliancePartsPros.com
John Kilford
#3 Posted : Tuesday, June 2, 2009 5:02:03 AM(UTC)
John Kilford
I just wanted to say thank you to Gene, it was the thermal fuse, the repair was cheap and easy and now the dryer is running llike new :D
#4 Posted : Wednesday, June 3, 2009 9:32:34 PM(UTC)
You are welcome, John. I'm glad you were able to fix it.
jfamily20
#5 Posted : Monday, July 6, 2009 5:13:54 PM(UTC)
jfamily20
do i need a new fuse?
#6 Posted : Monday, July 6, 2009 6:39:47 PM(UTC)
What is it all about?
Guest (5)
Whirlpool dryer light (Dryer Repair)
by Guest 6/19/2024 12:27:19 PM(UTC)
Whirlpool dryer WED7500VW1 won’t turn on (Dryer Repair)
by tryingmybest 11/15/2023 4:40:47 PM(UTC)
Whirlpool dryer wire (Dryer Repair)
by Guest 10/20/2023 10:51:08 AM(UTC)
Whirlpool dryer heavy load turning (Dryer Repair)
by Guest 3/28/2023 5:58:08 PM(UTC)
YWED7500VW0 - Looking whirlpool dryer belt access procedure (Dryer Repair)
by Toronto_18_2703 11/4/2022 12:46:25 PM(UTC)
Whirlpool Dryer Knocking Noise (Dryer Repair)
by Guest 8/31/2022 5:01:42 PM(UTC)
Whirlpool Dryer sensor light on and never starts (Dryer Repair)
by CPepe 8/27/2022 11:48:56 AM(UTC)
Whirlpool Dryer WGD5300SQ0 taking too long to dry (Dryer Repair)
by aryan 4/10/2022 3:24:26 PM(UTC)
Whirlpool Dryer Model# W10151592A (Dryer Repair)
by Ssuarez 2/28/2022 4:22:11 PM(UTC)
Whirlpool dryer WED9500TW1 (Dryer Repair)
by Herm404 12/18/2021 12:39:46 PM(UTC)
WHIRLPOOL Dryer Repair Kit (27 Inch Wide Dryers, Thin Twins) - AP3109602 (4392067) (Dryer Repair)
by try2repairguy 12/9/2021 6:57:53 AM(UTC)
Whirlpool Dryer Fan Not Working (Dryer Repair)
by kkknie 11/21/2021 12:09:24 PM(UTC)
Whirlpool Dryer WED5790VQ1 (Dryer Repair)
by Guest 10/22/2021 3:39:17 PM(UTC)
whirlpool dryer codes persist (Dryer Repair)
by JMM12 7/30/2021 4:52:44 AM(UTC)
whirlpool dryer stops on sensing (Dryer Repair)
by Guest 5/16/2021 7:46:23 PM(UTC)
