larryp3
#1 Posted : Monday, July 6, 2009 11:53:20 AM(UTC)
larryp3
oven won't light. glow igniter doesn't go on. no power to it. checked for power at oven control knob nothing. circuit diagram shows a 5 amp fuse in circuit for oven glow igniter, can't find it. top burners work fine. just before failure wife heard sparking sound, then oven stopped working. found shorted wire at gas safety, repaired it, but can't find fuse. any idea where it is or type. thanks
Dan O.
#2 Posted : Monday, July 6, 2009 12:22:42 PM(UTC)
Dan O.
Quote:
Model Number: s610-3kx
I believe the "0" in the model number above should be a letter.
On some models it is inside the manifold panel (behind the burner knobs).
JFYI
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
larryp3
#3 Posted : Monday, July 6, 2009 3:28:17 PM(UTC)
larryp3
JFYI
Dan O.
=D~~~~~~
It could be an O. I removed the manfold panel looking for it,wasn't there and to check for voltage at the oven control. no voltage. looked for an inline fuse. according to circuit diagram its on the red wire between oven control and igniter. Went to back opened up the covers found red wire from above, but no fuse. Could I be looking at it and recognizing it.
Dan O.
#4 Posted : Monday, July 6, 2009 6:47:26 PM(UTC)
Dan O.
Quote:
It could be an O.
I meant besides the obvious "O". Maybe C, D, G, Q, etc. Did you double check it?
You traced the wire all the way from the control to the ignitor?
I don't know, it should be a automotive buss type fuse in some kind of housing.
LINK > Magic Chef 5 Amp Fuse
JFYI
Dan O.
=D~~~~~~
larryp3
#5 Posted : Monday, July 6, 2009 8:15:55 PM(UTC)
larryp3
JFYI
Dan O.
=D~~~~~~
wire leaves manifold area, goes into side wall and shows up in the back. I can't believe its hidden in the oven wall. looked up diagram for magic chef 61h . it looks identical to my unit but doesn't show a fuse.
Dan O.
#6 Posted : Monday, July 6, 2009 9:18:50 PM(UTC)
Dan O.
Did you try a continuity test from each end of the wire to see if current can flow though it unimpeded?
Continuity would mean there is no open fuse in that circuit so that couldn't be your the problem?? No continuity would mean there is something wrong in that wire somewhere.
Did you recheck the model number on your appliance's identification tag?
Dan O.
=D~~~~~~
larryp3
#7 Posted : Tuesday, July 7, 2009 5:21:32 AM(UTC)
larryp3
Dan O.
=D~~~~~~
Rechecked model number its right. Daughter bought the house 2 months ago, stove could be over 10yrs old. I will be away for next few days and won't be able to work on it til 7/14. Will check continuity when I get back. I'll let you know what I find. Thanks for your help.
Whirlpool WFG505MOBS0 - Oven Won't Light (Oven Repair (including Ranges and Cooktops))
by JeffraKing 11/15/2023 9:09:08 AM(UTC)
Thermador Gas oven won't light (Oven Repair (including Ranges and Cooktops))
by Guest 8/1/2023 8:48:27 AM(UTC)
Amana oven won't light (Oven Repair (including Ranges and Cooktops))
by rope13 1/10/2017 3:55:40 PM(UTC)
Help, my gas oven won't light..... (Oven Repair (including Ranges and Cooktops))
by lharrell79 3/17/2016 10:13:10 AM(UTC)
Oven won't light, hear click(s), no gas smell (Oven Repair (including Ranges and Cooktops))
by gizmodyne 4/26/2015 6:36:01 AM(UTC)
Kitchenaid Gas Oven Won't Light (Oven Repair (including Ranges and Cooktops))
by Chris Ricc 1/7/2015 8:13:37 PM(UTC)
Oven won't light (Oven Repair (including Ranges and Cooktops))
by davidr222 7/31/2014 7:01:18 AM(UTC)
Magic Chef Oven Won't Light (Oven Repair (including Ranges and Cooktops))
by miisu 1/21/2014 4:55:33 PM(UTC)
Oven won't light; shuts off with F2 Error during pre heat (Oven Repair (including Ranges and Cooktops))
by MaxRock 11/21/2013 2:12:32 PM(UTC)
Whirlpool Oven Won't light (Oven Repair (including Ranges and Cooktops))
by klucich 5/13/2013 4:36:10 AM(UTC)
Frigidaire oven won't light (Oven Repair (including Ranges and Cooktops))
by baltojeff 12/7/2012 6:58:35 AM(UTC)
Roper Oven won't light (Oven Repair (including Ranges and Cooktops))
by LoneMedic 11/9/2012 10:15:54 AM(UTC)
gas broiler and oven won't light (Oven Repair (including Ranges and Cooktops))
by rickric 8/27/2012 4:16:55 PM(UTC)
GE Profile, oven won't light (Oven Repair (including Ranges and Cooktops))
by Buggus 8/1/2012 4:05:34 AM(UTC)
by gregew 7/10/2012 7:47:10 AM(UTC)
