roy
twodesk
#1 Posted : Thursday, June 25, 2009 7:31:50 AM(UTC)
twodesk
Water Line In Freezer To The Ice Machine Is Freezen Up,,change The Water Valve--- Line Is Still Freezen Up What Did I Do Wrong ?
#2 Posted : Thursday, June 25, 2009 1:30:24 PM(UTC)
How old is the water filter? How good is the water pressure from the water dispenser?
twodesk
#3 Posted : Thursday, June 25, 2009 7:41:43 PM(UTC)
twodesk
water filter is 4 months old water pressure is good glass fill quickly
twodesk
#4 Posted : Thursday, June 25, 2009 8:03:18 PM(UTC)
twodesk
Gene, the water filter is about 4 months old--the water out of the dispencer is good pressure even took hair dryer to melt the ice in tube to the ice machine
#5 Posted : Thursday, June 25, 2009 8:32:43 PM(UTC)
Make sure the water line to the ice maker is clear. Remove the water filter and install the filter bypass (#791 on the diagram). Watch the water line for a couple days and post the results.
Royal Chef built in 1957 (Oven Repair (including Ranges and Cooktops))
by Laura Harris 10/19/2021 2:40:09 PM(UTC)
Whirlpool washing machine destroying water pumps (Washer Repair)
by mjcarb 8/30/2016 11:53:49 AM(UTC)
self cleaning = self destroy (Oven Repair (including Ranges and Cooktops))
by chrisgski 6/26/2013 6:07:51 PM(UTC)
permanent flexible gas connector destroyed (Dryer Repair)
by memann04 2/1/2013 1:12:38 PM(UTC)
Troy (Washer Repair)
by Troy Bunkers 1/16/2013 11:36:46 AM(UTC)
robroy1958@msn.com (Refrigerator & Freezer Repair)
by ritzman 3/10/2012 7:31:31 AM(UTC)
Roy Nelson (Oven Repair (including Ranges and Cooktops))
by Roy Nelson 4/16/2010 6:18:20 AM(UTC)
Duet destroying Outer Tubs (Washer Repair)
by razorback85 12/24/2009 7:46:06 AM(UTC)
Whirlpool duet destroying front tubs (Oven Repair (including Ranges and Cooktops))
by razorback85 12/24/2009 7:41:51 AM(UTC)
royal chef gas oven (Oven Repair (including Ranges and Cooktops))
by mfrazier 9/12/2009 8:13:51 AM(UTC)
chef royale (Oven Repair (including Ranges and Cooktops))
by geoffvinc 7/13/2009 3:40:35 PM(UTC)
remove old destroyed cooktop and install new cooktop (Oven Repair (including Ranges and Cooktops))
by richlibl 7/6/2009 9:32:45 AM(UTC)
Kenmore Washer destroying my life! need help (Washer Repair)
by noobRepairMan 3/12/2009 9:14:30 AM(UTC)
Royal Chef (Oven Repair (including Ranges and Cooktops))
by farhorse6 12/20/2008 5:37:13 AM(UTC)
