Water Line In Freezer To The Ice Machine Is Freezen Up,,change The Water Valve--- Line Is Still Freezen Up What Did I Do Wrong ?
How old is the water filter? How good is the water pressure from the water dispenser?
water filter is 4 months old water pressure is good glass fill quickly
Gene, the water filter is about 4 months old--the water out of the dispencer is good pressure even took hair dryer to melt the ice in tube to the ice machine
Make sure the water line to the ice maker is clear. Remove the water filter and install the filter bypass (#791 on the diagram). Watch the water line for a couple days and post the results. Gene.
