It has water around gasket on freezer....
Looking at the parts I see that the unit has a Power Saver switch as part of the controls.
Turn Power saver off. This then turns on a heater in the frame and reduces/eliminates condensation around the door. When the ambient humidity gets to a lower level (winter depending wherer you live) you can turn it back on.
I also would check that the door is sealing correctly. Take a 2 inch wide piece of paper and place it between the door and the frame. Then pull it out to see if the seal is good. Work your way around the door. |
THIS FORUM IS DEAD!!!!!!! |
