lmkot
#1 Posted : Sunday, March 5, 2017 9:39:46 PM(UTC)
lmkot
The dryer turns itself off within minutes when running on timed dry with heat. It used to do it when running on high heat, then on medium, now also on low. However it heats up high even on a low setting (which is fine by me, as I like to dry most of my clothes on high heat). When I start another timed drying cycle right after the dryer stopped, it starts again fine and then often stops within a minute. I can also usually just continue, although about third of the time, it won't continue, possibly cause it is too hot (the clothes feel really hot then). I usually have to restart the dryer many times to get my clothes to dry. If I run it on 'air only' there is no problem - it continues to the end of cycle.
I'm guessing that I need to replace a thermostat but I'm not certain. Any input appreciated.
Lidia
brobriffin
#2 Posted : Wednesday, March 8, 2017 4:54:03 PM(UTC)
brobriffin
Man
United States
When is the last time you had your dryer vent system completely cleaned? Delinted!
Over heating can occur due to a clogged dryer vent (fire hazard as well) and cause your symptoms.
Thermister = cycling the gas heater on and off from about 160 -165ish degrees to 125-130ish degrees.
Hi-Limit thermostat = Like a thermal fuse once popped must be replaced
lmkot
#3 Posted : Wednesday, March 15, 2017 9:14:41 PM(UTC)
lmkot
Thank you for responding. I cleaned out the vent system this morning - it was not clogged. I took the vent pipe off from the back and vacuumed inside. The issue with dryer stopping is still there. I'll go with replacing Thermister next. It does not sound like Hi-limit thermostat, since the heat comes on just fine.
Gas Dryer turns off early (Dryer Repair)
by giorfido 12/31/2022 8:36:38 AM(UTC)
Dryer Turns off in less than 30 seconds. (Dryer Repair)
by GalyonGal 4/7/2018 2:56:42 PM(UTC)
Whirlpool dryer turns off when using high heat (Dryer Repair)
by SheepNutz 6/24/2017 8:00:00 PM(UTC)
Dryer turns off mid cycle and then turns itself back on (Dryer Repair)
by acosto04 12/24/2012 1:19:34 PM(UTC)
dryer turns off after few minutes (Dryer Repair)
by jpstep 6/19/2012 12:33:45 PM(UTC)
Whirlpool Dryer turns off (Dryer Repair)
by AHESCOBEDO75 8/25/2011 5:23:26 PM(UTC)
Dryer turns off after 10 min (Dryer Repair)
by clarence ray 12/31/2010 2:26:48 PM(UTC)
Dryer turns off after a few seconds (Dryer Repair)
by Tanzee 12/15/2010 1:32:13 PM(UTC)
by llano339 11/3/2010 3:57:46 PM(UTC)
Dryer turns off autmatically in TIMED mode but not the others, delicate, cotton etc. (Dryer Repair)
by Rawbert 1/15/2010 3:15:58 PM(UTC)
dryer turns off and won,t restart for about an hour (Dryer Repair)
by captainda 12/6/2009 5:48:35 AM(UTC)
by Jarhead72 6/27/2009 7:28:56 AM(UTC)
dryer turns off before cycle complete (Dryer Repair)
by AmyC 5/1/2009 1:24:09 PM(UTC)
gas dryer turns off(timer runs) re starts on own?? (Dryer Repair)
by efniatet 12/7/2008 6:21:27 PM(UTC)
