It worked great until the other day when we decided to use the self cleaning feature. Now the oven is very clean but will not heat up at all, Bake or Broil. Does anybody have any suggestions. Thanks Larry
Here are your parts Replacement parts for WHIRLPOOL RBS305PDB8 | AppliancePartsPros.comHere is a tech sheet https://www.servicematters.com/d...0Sheet%20-%204451884.pdfTurn your breakers off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker. If this does nothing it is best to measure the voltage at the oven. Try cutting power off to the unit for half an hour or so. A long shot but worth a try. Since you have no errors I would check out the over temp thermostat. Item 37 in the "Oven, literature" section. Be sure to have the power off, remove a wire from one of it's connectors and check it with a meter. Should be 0 ohms. |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman Here are your parts Replacement parts for WHIRLPOOL RBS305PDB8 | AppliancePartsPros.comHere is a tech sheet https://www.servicematters.com/d...0Sheet%20-%204451884.pdfTurn your breakers off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker. If this does nothing it is best to measure the voltage at the oven. Try cutting power off to the unit for half an hour or so. A long shot but worth a try. Since you have no errors I would check out the over temp thermostat. Item 37 in the "Oven, literature" section. Be sure to have the power off, remove a wire from one of it's connectors and check it with a meter. Should be 0 ohms. Denman, Took me awhile to find this post but wanted to let you know I replaced both upper and lower elements in oven because they looked fried and it did not help with my oven not working. where is the oven temp thermostat located? Does the oven have to be pulled out to get to it? thks Lcren11
It looks like it is mounted on the outside oven the oven cavity wall so the oven will have to be pulled.
Note they call it a thermostat when in reality it is a thermal fuse. |
Ok, Thanks I'll get it pulled and check it out and will let you know. Thks again Lcren11
Denman, Thanks for the help it was the thermal fuse thermostat!!!!!!One other thing while I have you, how do you get to the front door glass to clean? I took out screws but it will not let me remove cover. I did not want to force it and break it. Thks Lcren11
Hey its been a few days, anybody home!!!!!!!!!!!!!!!
Thanks Denman, Hope you had fun at the lake!!!!!!!!!!!!!Have a great weekend. Lcren11
