danno50
#1 Posted : Thursday, August 26, 2010 11:37:05 AM(UTC)
danno50
I have a Whirlpool cooktop Model gjc3034lb02. The large dual zone accu-simmer burner will only operate on high and will not on a lower heat. I think it's the switch that went bad. I am not sure which switch to order.
whirlpool cooktop on light won't go out (Oven Repair (including Ranges and Cooktops))
by mkae15 8/2/2015 2:47:40 PM(UTC)
Whirlpool cooktop burner on max only (Oven Repair (including Ranges and Cooktops))
by PotRoastMan 11/8/2014 5:09:52 PM(UTC)
Whirlpool Cooktop Igniter - Popping Breaker (Oven Repair (including Ranges and Cooktops))
by KevinJ123 12/25/2013 9:01:58 PM(UTC)
Whirlpool Cooktop Temperature Control Problem (Oven Repair (including Ranges and Cooktops))
by fpltdc 10/30/2013 9:28:41 AM(UTC)
whirlpool cooktop burners heats slow minimum heat on all burners (Oven Repair (including Ranges and Cooktops))
by wigginscallie@yahoo,com 8/15/2013 7:09:45 PM(UTC)
Replacing Cable on Whirlpool Cooktop (Oven Repair (including Ranges and Cooktops))
by MAD King 3/25/2013 6:14:10 AM(UTC)
whirlpool cooktop ignitors doesn't work after clean up (Oven Repair (including Ranges and Cooktops))
by zhtway 4/16/2012 11:01:05 AM(UTC)
whirlpool cooktop help (Oven Repair (including Ranges and Cooktops))
by mross08226 12/4/2011 4:17:52 PM(UTC)
Ceramic Whirlpool Cooktop will not turn off (Oven Repair (including Ranges and Cooktops))
by RandallRock 11/25/2011 3:14:18 PM(UTC)
Surface Element Removal on Whirlpool Cooktop (Oven Repair (including Ranges and Cooktops))
by trot1107 4/6/2011 7:07:04 AM(UTC)
by PHYLLIS695 11/2/2010 12:55:42 PM(UTC)
Need help removing Whirlpool cooktop (Oven Repair (including Ranges and Cooktops))
by papasaun 11/17/2009 1:43:02 PM(UTC)
Whirlpool cooktop ignitor replacement (Oven Repair (including Ranges and Cooktops))
by DeweyPtui 11/22/2008 12:33:03 PM(UTC)
Whirlpool cooktop staying on (Oven Repair (including Ranges and Cooktops))
by hmbsparks 6/8/2008 3:03:58 PM(UTC)
Whirlpool Cooktop Surface Replacement (Oven Repair (including Ranges and Cooktops))
by nsack 12/20/2007 9:31:40 AM(UTC)
