littlemsenee
#1 Posted : Thursday, August 12, 2010 3:55:19 PM(UTC)
littlemsenee
freezer defrosted refrigerater side isnt getting cold
#2 Posted : Friday, August 13, 2010 3:11:42 AM(UTC)
Replacement parts for MAYTAG MSD2651HEW Ref - SXS/I&W | AppliancePartsPros.com
Not sure if I understand your post.
If you mean that the evaporator coils in the freezer section are not iced up and the freezer temperature is good, then I would check the damper (Item 8 in Section 7). It should be open.
Also check that the evaporator fan is running. It is required to push cold air into the fresh food section.
Also that Item 19 in Section 11 is not blocked by a food items. I believe this is an air return grill between the two sections.
GE Refrigerator DFE29JSDASS (Dishwasher Repair)
by DOUGZARA 4/24/2024 9:43:25 AM(UTC)
Electrolux Refrigerator not getting cold (Refrigerator & Freezer Repair)
by jesus freak 3/30/2024 1:11:55 AM(UTC)
Kitchenaid Refrigerator Ice chute frosting up and clogging (Refrigerator & Freezer Repair)
by Guest 3/26/2024 9:05:12 AM(UTC)
Built-In Kitchenaid Mdel KSSC42QMS00 Refrigerator (Refrigerator & Freezer Repair)
by Guest 3/25/2024 6:29:18 AM(UTC)
Samsung Refrigerator - Service Kit for Icing Issue (Refrigerator & Freezer Repair)
by keith1386 3/24/2024 8:57:57 AM(UTC)
Automatic water filter bypass - Whirlpool Refrigerator GD5SHAXLQ02 (Refrigerator & Freezer Repair)
by z-vap 2/28/2024 2:08:23 PM(UTC)
Maytag Refrigerator freezing food on lowest setting (Refrigerator & Freezer Repair)
by ilgy 2/15/2024 8:14:17 AM(UTC)
EA120 EA150 Bosch Error Code - Built In Refrigerator (Refrigerator & Freezer Repair)
by Peter Franks 2/13/2024 4:55:41 PM(UTC)
Freezer holding at 22 degrees and ice maker (located in refrigerator cabin) isn't working (Refrigerator & Freezer Repair)
by eric5605 2/13/2024 4:35:48 AM(UTC)
Kenmore refrigerator/freezer issue (Refrigerator & Freezer Repair)
by rgbradley58 1/30/2024 6:32:20 AM(UTC)
Power Surge damage to Refrigerator and Clothes Drier (Refrigerator & Freezer Repair)
by CBorucki 1/21/2024 7:29:43 AM(UTC)
Frigidaire Refrigerator model 253.56602402 issue (Refrigerator & Freezer Repair)
by anitak4242 1/17/2024 8:32:53 PM(UTC)
Whirlpool Refrigerator question (Dishwasher Repair)
by staffx4 1/9/2024 11:15:21 AM(UTC)
Frigidaire Gallery Refrigerator GRFS2853AF4 - Freezer not working (Refrigerator & Freezer Repair)
by Repaircat 1/9/2024 8:08:53 AM(UTC)
Frigidaire Refrigerator FRS24XGCB1 (Refrigerator & Freezer Repair)
by Guest 1/1/2024 12:18:22 PM(UTC)
