LCooper
#1 Posted : Tuesday, May 13, 2008 7:15:19 AM(UTC)
LCooper
Maytag Neptune started about a year ago just beeping for no reason. Eventually beeped for no apartant reason during wash cycle. Time left display would jump around with no action and then it would complete cycle. Now when you power it up pushing any button does nothing but beeps twice. After a couple minutes several lights including start pause light flashes. At this point you can either push cotton strudy or wrinkle free and it lights up, at this point you can only change the water temp and the buttons presoak,sain cycle, extra rinse and max extract. If you hit start it will proceed to wash completely with no problems. Called local Maytag man and he agreed it sounded like the control board. He would never get back to me so I finally ordered a new control board. SAME THING. I've electricaly trouble shooted door closed circuit and tub displacement, front weight disp sw and inertial unblance switch and all are fine. I even checked continuity on the led membrane cord and all switches work perfectly EXCEPT (presoak, stain cycle,extra rinse,max extract) buttons I get no conintuity between these. HOWEVER like I stated above I can change these settings now after I first plug it in like I said above and wait till it starts several of the leds blinking these and the water temp is the only buttons that do work!!! HELP
#2 Posted : Tuesday, May 13, 2008 7:00:37 PM(UTC)
The first thing I would do is check for a proper connections of all ground and neutral wires and terminals.
LCooper
#3 Posted : Wednesday, May 14, 2008 10:47:24 AM(UTC)
LCooper
Well I thought the same. I checked volatage at recp before and under load. Have had the recep out and checked it. I even unhooked the earth ground temp incase of some kinda interference on it. All checked and looked fine.
I honestly have no clue. I'm no washer repairman either am I electronic eng. Just a simple electrician! lol I'm pretty sure unless someone has had prior experience with this type of trouble it's down to parts changing to find. And that gets expensive at this rate. I know now more of what I'll be looking at when I buy a replacement washer.
I honestly believe its my LED membrane pad even though it all checks out with the exceptions I mentioned above. However those dang buttons that I can't get continuity on work when it finally does decide to run a cycle. Unless under load the led lights or buttons are "shorting out" because alot of the same pins on the ribbon connector have multiple contacts for other buttons. I'm thinking one or more of the buttons underload are looking "pushed" in upon startup! Much like if a phone number button was "stuck' in the other buttons wouldn't work right either.
#4 Posted : Wednesday, May 14, 2008 5:46:32 PM(UTC)
Pull each terminal of the white wire harness connected to each water valve solenoid and verify the wire is properly stripped and crimped to the metal terminal connector of the wire harness. Make sure the wires fit snug on the terminals of the water valve solenoids.
If it would not help then the console assembly has to be replaced. In order to provide the right part number I need the color of the control panel.
Here are the break down diagrams for the Maytag Neptune washer Model MAH5500BWW
Guest
#5 Posted : Saturday, March 23, 2024 9:53:00 PM(UTC)
Guest
Rank: Guest
United States
Definitely sounds like your control panel. I would look on ebay and buy one. I had the same issue.
maytag front loader washer model# mhwe300vf00 (Washer Repair)
by Guest 9/26/2021 9:57:51 AM(UTC)
Maytag Front Loader not dispensing bleach or fabric softner (Washer Repair)
by Ron1404 12/18/2016 3:42:55 PM(UTC)
Maytag Front Loader FH (Washer Repair)
by MyNameIsNate 8/2/2016 2:09:50 PM(UTC)
Maytag front loader washer will not extract water from clothes all the time (Washer Repair)
by jsegura525 1/1/2015 7:48:41 AM(UTC)
UNBALANCED load - Maytag front loader MAH7500AWW (Washer Repair)
by mrogge 10/1/2014 7:40:59 AM(UTC)
Maytag front loader 2000 series problem (Washer Repair)
by amarilloscout 10/11/2013 7:16:35 PM(UTC)
Maytag front Loader GFCI- 110 ground (Washer Repair)
by Laph9979 4/28/2013 4:26:12 PM(UTC)
Maytag Front Loader Burning Smell (Washer Repair)
by raj58esh 1/21/2013 4:29:30 PM(UTC)
maytag front loader won't' spin (Washer Repair)
by tpettit 12/13/2011 7:00:07 PM(UTC)
Maytag front loader control panel or motor (Washer Repair)
by astephens99 3/16/2011 2:49:12 PM(UTC)
maytag front loader door locks/slam door (Washer Repair)
by m218perez 10/21/2010 9:35:00 AM(UTC)
MayTag Front Loader fuse (Washer Repair)
by kerthialfad 6/17/2010 12:58:40 PM(UTC)
Maytag front loader FH code (Washer Repair)
by tamiwalnut 1/28/2010 1:42:29 PM(UTC)
Maytag front loader (Dishwasher Repair)
by red574 1/4/2009 5:22:12 PM(UTC)
Overheating Maytag front loader (Washer Repair)
by richappy 11/16/2008 9:13:25 AM(UTC)
