2 Pages12>
ShawnQ
#1 Posted : Friday, August 5, 2011 10:04:03 AM(UTC)
ShawnQ
Hello all,
During a military deployment of just over 2yrs, I stored my washer and dryer. Unfortunately, it was not climate controlled.
Upon my return and after geting a new home, I installed the washer and dryer. Everything seems to work great except for the spin cycle on the washer. The door switch, agitator, and drain are all fine...it just won't spin dry.
During the spin dry, it seems to smell like a clutch or brakes, or maybe a hot electric motor, but not a rubbr smell.
Where should I look first?
Thanks in advance.
Shawn
Joe / APP Team
#2 Posted : Friday, August 5, 2011 10:38:57 AM(UTC)
Joe / APP Team
Originally Posted by: ShawnQ Go to Quoted Post
Hello all,
Thanks in advance.
Shawn
Shawn,
Start be checking for something stuck between the tubs , or tub top and tub cover, Then slowly turn the inner tub a couple of revolutions.
Then check for a slipping clutch,
Part number: AP3094537
Here's some info from our Repair Forum Posts :
http://forum.appliancepartspros...-washer-brake-shoes.html
Good Luck,
ShawnQ
#3 Posted : Friday, August 5, 2011 1:59:21 PM(UTC)
ShawnQ
Joe,
Thanks for the response.
It does not appear to have anything between the tub and tub top, or between the tubs.
When I searched prior to posting, it sounded to me like it was likely a stuck braking system. When I try to turn the inner tub, I can't make it move at all (except for a rocking motion for the agitator function). I can't make it spin with just my hands.
The washer was stored in a storage unit that was not climate controlled which makes me think the braking system may have seized up from the high humidity.
What is the best way to go about checking the braking system?
Is there instructions anywhere on how to remove the case/body of the washer?
Thanks,
Shawn
RC Cola
#4 Posted : Friday, August 5, 2011 7:24:09 PM(UTC)
RC Cola
Hello all,
Thanks in advance.
Shawn
Shawn,
I have a problem very similar to yours and my problem is the clutch. The repairman checked the basket drive block for damage but mine is fine. Tomorrow he will be replacing the clutch as well as the dog ears on the agitator.
My brother-in-law is also taking a class on appliance repair and his instructor told him that my problem was due to the clutch. So, I will let you know if my washer works tomorrow.
ShawnQ
#5 Posted : Friday, August 5, 2011 8:17:53 PM(UTC)
ShawnQ
Originally Posted by: RC Cola Go to Quoted Post
Shawn,
RC,
Thanks for the info.
Were you able to spin your tub by hand? Mine seems to be locked...
Thanks again,
Shawn
ShawnQ
#6 Posted : Saturday, August 6, 2011 4:38:30 PM(UTC)
ShawnQ
Update:
I took the case off of the washer today. If I set the thecycle to spin, trip the door switch, the motor is visibly spinning and I can see what I think is the clutch drum spinning. However, I still can't get the tub to spin. When it is on, I can't make it spin by hand either...
Sound like a clutch or brake issue?
Should I expect it to be worthwhile to buy parts and repair it, or should I scrap it and get a new one?
Thanks in advance. Id like to get this finished, but not sure where to go from here.
Shawn
RC Cola
#7 Posted : Sunday, August 7, 2011 5:06:25 PM(UTC)
RC Cola
Update:
Shawn
Hello Shawn,
Sometimes the tub would be locked and sometimes I could turn it by hand. My machine has been fixed and I am very happy. My machine is also a Whirlpool direct drive washing machine. The problem was the clutch.
My husband wanted to buy a new washing machine but I insisted on the repiair and not that it has been fixed I am very happy.
Check out the following web page for more info reg what to check when your washing machine does not spin:
Whirlpool washer is not spinning
Good luck, let me know what happens
ShawnQ
#8 Posted : Monday, August 8, 2011 9:54:38 AM(UTC)
ShawnQ
I fixed mine also...
Mine ended up being a stuck brake mechanism. They were usted/seized from sitting in a humid storage facility for over 2yrs.
Thanks for the advice!
Shawn
Joe / APP Team
#9 Posted : Monday, August 8, 2011 10:17:53 AM(UTC)
Joe / APP Team
Shawn
Shawn,
Was there a problem with the attachment from the Repair Forum Post, that I sent you ?
It's a very good and concise report and has helped an awful lot of people in the past.
I'm pretty sure( almost 100% ) your going to find a slipping clutch, once you have the assembly removed.
ShawnQ
#10 Posted : Monday, August 8, 2011 2:25:24 PM(UTC)
ShawnQ
I removed everything based on the report...clutch seemed fine. I got it all workimg once I un-stuck the brake shoes from the drum. Works great now!
Guest (4)
no spin cycle on regular or permanent cycles only delicate cycle (Washer Repair)
by bhartwig 9/3/2016 5:44:07 PM(UTC)
No spin cycle on washer...need help (Washer Repair)
by 1moretoy 11/4/2014 3:57:35 PM(UTC)
Frigidaire Stackable Lid Switch Bypass no spin cycle (Washer Repair)
by billumd 9/26/2014 6:51:48 PM(UTC)
no spin cycle so clothes stay wet (Washer Repair)
by pmt1231 6/3/2014 8:23:30 PM(UTC)
Maytag Atlantis No Spin Cycle Replaced Thrust Bearing. (Washer Repair)
by MarkBe 12/21/2013 7:36:46 AM(UTC)
kenmore ~ no spin cycle (Dishwasher Repair)
by chrismo13 8/10/2013 12:42:54 PM(UTC)
No Spin Cycle (Washer Repair)
by KJH1961 1/16/2013 2:36:43 PM(UTC)
No spin cycle (Washer Repair)
by baldguywithagoat 10/8/2012 1:56:22 AM(UTC)
I replaced maytag mav6200aww brake, now no spin cycle (Washer Repair)
by jmlaudate 9/4/2012 4:28:43 PM(UTC)
Washer tumbles but no spin cycle (Washer Repair)
by jrwhitton 8/8/2012 9:13:05 AM(UTC)
Tumbles but no Spin Cycle (Washer Repair)
by Rob2001 7/23/2012 2:33:29 PM(UTC)
by John Foley 4/29/2012 11:46:11 AM(UTC)
No spin cycle or drain? Lid switch? (Washer Repair)
by 9n1Ed 4/27/2012 10:47:15 PM(UTC)
by firefly 4/27/2012 10:18:46 AM(UTC)
GE washer no spin cycle (Washer Repair)
by fsuglover 4/8/2012 4:41:33 PM(UTC)
2 Pages12>
