dick2256@hotmail.com
#1 Posted : Tuesday, July 24, 2007 10:08:19 AM(UTC)
It appears the pump is working but it won't discharge the water from the tub
Anyone have any Idea what part I may need.
Is there a seloniod that should be closing off the other functions of the water pump?
Admin / APP Team
#2 Posted : Tuesday, July 24, 2007 10:43:32 AM(UTC)
Admin / APP Team
Rank: Administration
Groups: Guests
Do you have an airgap installed at the sink? Take a look at this airgap diagram. If there is an airgap, unscrew the top cap and see if it's clogged up. Clean it out and run the dishwasher again. If there is no airgap, check the dishwasher drain hose.
Let us know how it goes. If none of this solves the problem, post back and we'll go from there.
#3 Posted : Tuesday, July 24, 2007 11:38:15 AM(UTC)
thanks for your fast reply
I pulled the drain hose off at the check valve and it was badly
plugged with lint and such and also a plastic button that holds the
silverware tray on the door was missing and I found peices of it lodged in the check valve also.
Dick
Admin / APP Team
#4 Posted : Tuesday, July 24, 2007 12:30:21 PM(UTC)
Admin / APP Team
Groups: Guests
Good job. I'm glad it's fixed. Check valve and the pump in general would have been the next thing I'd ask you to check.
The reason why I pointed you to the airgap first was because it's a good idea to start troubleshooting from a) the most common cause b) most simple things to check. For example, if your appliance doesn't show any signs of life, check the circuit breaker and the plug first, before taking the control panel apart, etc.
By the way, check the door. Make sure there is no hole where the plastic button used to be.
Bosch dishwasher SHVM78Z53N/01 (Dishwasher Repair)
by Guest 5/8/2024 8:58:29 PM(UTC)
Continuity TEst Samsung p/n 33299012 Dishwasher Water Inlet Valve. (Dishwasher Repair)
by cprodave 4/27/2024 6:55:56 PM(UTC)
Samsung DMT400RHS Dishwasher Over Level Water Error. (Dishwasher Repair)
by cprodave 4/27/2024 6:24:56 PM(UTC)
Samsung Dishwasher Water Inlet Valve--how to Test? (Dishwasher Repair)
by cprodave 4/27/2024 6:18:51 PM(UTC)
Kitchen aid dishwasher bottom leaking (Dishwasher Repair)
by Guest 4/21/2024 10:31:25 AM(UTC)
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest 3/11/2024 7:00:18 PM(UTC)
Kenmore 90 665 dishwasher noise from impellor (Dishwasher Repair)
by Guest 3/10/2024 12:30:08 PM(UTC)
LG dishwasher bE Bubble Error (Dishwasher Repair)
by Guest 2/13/2024 10:58:29 AM(UTC)
Frigidaire dishwasher 2nd water inlet valve fails (Dishwasher Repair)
by Guest 2/13/2024 3:32:15 AM(UTC)
Dishwasher fills and drains only. Does not go through the wash and rinse cycle (Dishwasher Repair)
by Guest 2/11/2024 6:26:48 AM(UTC)
Maytag dishwasher model MDB4949SKZ1 (Dishwasher Repair)
by thepontif 2/3/2024 11:15:46 AM(UTC)
#DW80F600UTS Samsung Dishwasher High Temperature Heating Error (Dishwasher Repair)
by Guest 1/24/2024 6:35:24 AM(UTC)
GE Dishwasher GDF620HMJ2ES (Dishwasher Repair)
by lou@officenerd.com 1/14/2024 3:32:20 PM(UTC)
