raulrio
#1 Posted : Saturday, November 14, 2009 10:24:32 AM(UTC)
raulrio
:mad: The broiler does not heat on my Maytag MER5775QAB. I purchased and installed a new broiler element, problem still exists. The bake and cleaning functions work fine as well as all others. What do I need to do, replace next?
Sincerely,
Raul
#2 Posted : Sunday, November 15, 2009 2:42:12 AM(UTC)
Replacement parts for MAYTAG MER5775QAB | AppliancePartsPros.com
Here is some technical info
http://www.servicematters.com/m...ibrary/docs/16025644.pdf
http://www.servicematters.com/m...ibrary/docs/16025648.pdf
http://www.servicematters.com/m...rary/docs/TDC-0065-B.pdf
Wiring diagram seems to indicate that the thermal limiter (if your unit has one) would remove power from both bake and broil.
If this is correct then all that is left is a wire has burned off somewhere in the unit or the control board is shot.
raulrio
#3 Posted : Sunday, November 15, 2009 5:58:23 AM(UTC)
raulrio
fpr the information and references, I'll study and try to find the problem.
Thanks Again,
Raul
raulrio
#4 Posted : Sunday, November 22, 2009 11:17:41 AM(UTC)
raulrio
I had the Maytag repair person make a visit, and he thinks is the clock module. I am already out of $38 for the broiler element and $65 for the service call. Would the $139 for the module fix it, or can it be something else and more money gone? Is it worth fixing given that is a stove bought in 2004, but was built in 2000?
Raul
#5 Posted : Monday, November 23, 2009 1:07:48 AM(UTC)
Cannot say since I do not know the competence of your service tech. If the high limit is OK and the wires to the element are OK then odds are very high that the control board is the problem.
Again I cannot say. Depends on a lot of things re:
Do you like the unit?
Is it in good shape?
How much would a replacement unit that you would be happy with cost?
raulrio
#6 Posted : Tuesday, November 24, 2009 12:06:45 PM(UTC)
raulrio
I appreciate the advise,
Raul
Oven and Broiler not working (Oven Repair (including Ranges and Cooktops))
by Broncojo 5/22/2015 4:03:12 PM(UTC)
Tappan oven and broiler not working (Oven Repair (including Ranges and Cooktops))
by mrthtolan@yahoo.com 10/15/2014 6:44:08 AM(UTC)
oven and broiler not working, need part (Oven Repair (including Ranges and Cooktops))
by Todd F 9/24/2014 6:16:39 PM(UTC)
Frigidaire Oven broiler not working (Oven Repair (including Ranges and Cooktops))
by isitjustme 8/28/2014 12:43:06 PM(UTC)
Tappan TEF326FBA Oven & Broiler Not Working (Oven Repair (including Ranges and Cooktops))
by jgorrz 1/9/2014 5:46:17 PM(UTC)
Upper oven broiler not working (Oven Repair (including Ranges and Cooktops))
by Johnswales@bellsouth.net 12/14/2013 6:12:51 AM(UTC)
Older GE oven broiler not working (Oven Repair (including Ranges and Cooktops))
by rabatvilla 3/7/2013 5:08:51 PM(UTC)
Kenmore oven & broiler not working (Oven Repair (including Ranges and Cooktops))
by jennyl6873 1/18/2013 6:59:38 AM(UTC)
Accubake Broiler Not Working (Oven Repair (including Ranges and Cooktops))
by husky300 12/17/2012 10:16:57 AM(UTC)
Top Broiler not working (Oven Repair (including Ranges and Cooktops))
by mbrangers84 12/8/2012 7:43:59 AM(UTC)
Jenn Air upper broiler not working (Oven Repair (including Ranges and Cooktops))
by fgo2 8/14/2012 2:29:10 PM(UTC)
by Cody Moss 6/18/2012 7:32:59 PM(UTC)
Oven and broiler not working (Oven Repair (including Ranges and Cooktops))
by boomer913 3/14/2012 1:13:25 PM(UTC)
by boomer913 3/14/2012 1:00:22 PM(UTC)
oven abd broiler not working (Oven Repair (including Ranges and Cooktops))
by Dianedeon123 12/22/2011 10:22:50 PM(UTC)
