boomer913
#1 Posted : Wednesday, March 14, 2012 1:00:22 PM(UTC)
boomer913
oven and broiler not working
Joe / APP Team
#2 Posted : Wednesday, March 14, 2012 1:33:17 PM(UTC)
Joe / APP Team
Boomer,
We'll presume the cooktop burners and other switches work.
If that's the case, you should have 220 - 240 volts into the range. You'll need to remove power to the range, remove the top and bottom cover panels on the back and check the red and black wires into the control and the three wires from the control to both the bake and broil elements, for damage, burns, breaks, etc.
If you have a multimeter, you can check the wires for a closed circuit from end to end. You would also want to disconnect the wires at the element terminals and check for a "closed" circuit across the element terminals. If all checks are OK, the issue would be in the ERC/Clock.
Part number: AP3561834
Here's some meter usage information, if you need it
http://forum.appliancepartspros...continuity-ohmmeter.html
Good Luck and Thanks,
Oven and Broiler not working (Oven Repair (including Ranges and Cooktops))
by Broncojo 5/22/2015 4:03:12 PM(UTC)
Tappan oven and broiler not working (Oven Repair (including Ranges and Cooktops))
by mrthtolan@yahoo.com 10/15/2014 6:44:08 AM(UTC)
oven and broiler not working, need part (Oven Repair (including Ranges and Cooktops))
by Todd F 9/24/2014 6:16:39 PM(UTC)
by Cody Moss 6/18/2012 7:32:59 PM(UTC)
Oven and broiler not working (Oven Repair (including Ranges and Cooktops))
by boomer913 3/14/2012 1:13:25 PM(UTC)
by JimConlon 12/13/2011 10:22:01 AM(UTC)
Oven And Broiler Not Working (Oven Repair (including Ranges and Cooktops))
by MACH1MUSTANG 1/20/2010 1:30:33 PM(UTC)
oven and broiler not working the stoetop does (Oven Repair (including Ranges and Cooktops))
by markk 2/5/2008 7:02:15 PM(UTC)
