my oven pilot lights but the oven / broiler does not...I've replaced the safety gas valve, the igniter, and the spark module. it still does the same thing. oven igniter works the pilot will light and even after fifteen / twenty and thirty seconds the oven still does not light. Any help? :(
Make sure the gas valve temperature sensing bulb is in the correct position (inside the pilot flame) and the pilot flame is good. Possible the pilot needs cleaning. 30 seconds can be not enough to heat up the sensing bulb. Sometime it can be over a minute. Here are the breakdown diagrams and Replacement parts for AMANA RLN383UW | AppliancePartsPros.comGene.
