todd mc.
#1 Posted : Monday, October 3, 2011 6:23:57 AM(UTC)
todd mc.
the timer on my dryer quit winding down,the dryer ran for 4 hours ,now it runs but don't heat.I had the thermal fuses and the element tested,they are good.can the timer control keep the element from heating up?I've changed the 30amp breaker and tested everything in the dryer except timer.
#2 Posted : Monday, October 3, 2011 7:27:10 AM(UTC)
Replacement parts for WHIRLPOOL RED4440VQ1 29"ELECTRIC DRYER | AppliancePartsPros.com
[COLOR="DarkRed"].can the timer control keep the element from heating up?[/COLOR]
Yes it can the heating coil gets power through the AB and BC timer contacts.
In timed dry does the timer advance when the motor is running?
In timed dry the timer motor is connected directly to the 240 volts by timer contacts TF. So if it advances you know that you have 240 volts to the unit.
When the original timer would not advance did you try it in both auto and timed dry modes?
It's motor gets power through different circuit paths depending on the mode.
Beside the thermal cut-off in the heater circuit you also have the operating thermostat and the hi-limit thermostat.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
File Attachment(s):
RED4440.pdf (139kb) downloaded 3 time(s).
todd mc.
#3 Posted : Monday, October 3, 2011 8:47:06 AM(UTC)
todd mc.
thank you very much for responding.the timer on the dryer does wind down on timed cycles but doesn't on autodry cycle, i had it on autodry and thats why it ran for so long. I do have an ohm meter and have checked all fuses and thermostats and the element, even the little white fuse over by vent tube.I also replaced the breaker in the house.So your saying that if timer winds down on timed cycle but not autodry,that my heating problem is not because of the timer.T%he timer is t5he only thing I havn't checked with ohm meter.Also even though timer winds down on timed cycles it still doesn't heat up.Thank u again!!!
#4 Posted : Tuesday, October 4, 2011 4:45:44 AM(UTC)
[COLOR="DarkRed"]checked all fuses and thermostats and the element, even the little white fuse over by vent tube.I also replaced the breaker in the house.So your saying that if timer winds down on timed cycle but not autodry,that my heating problem is not because of the timer.[/COLOR]
Not totally, you still could have contact problems in the timer.
But here is what it does tell you.
1. You have the 240 volts that the heating coil requires.
2. That the centrifugal switch on the motor is closing.
3. That for some reason the L2 voltage is not getting through the heater to run the timer motor when in auto cycles.
So the first thing to re-check is the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 10 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case.
If it is OK then reconnect the heating coil.
Leave the unit unplugged and set the timer to a mid scale timed dry cycle.
Set your meter to it's most sensitive scale.
Attach one meter lead to L1. This can be at the power cord plug or the timer (BK).
Now work you way back through the heater circuit.
BK on the timer should be 0 ohms
B on the timer should be 0 ohms
A on the timer should be 0 ohms
R at the Thermal Cutoff should be 0 ohms
R-w at the Thermal Cutoff should be 0 ohms.
R-W at the Operating Thermostat should be 0 ohms (both sides).
Be aware that the operating thermostat has 4 connectors. You want to measure on the red heavier wire connections.
R at Hi Limit should be 0 ohms (both sides).
Left side of heating coil (from the Hi Limit should be 0 ohms.
The right side of the heating coil should be 8 to 12 ohms.
FYI:
In timed dry the timer motor gets power directly from the line through the centrifugal switch and timer contacts T-F.
In auto modes it gets power through the centrifugal switch and the heating coil (when the heating coil is turned off by the operating thermostat) and timer contacts T-X.
Maytag electric dryer model MDE6400AYQ (Dryer Repair)
by Guest 3/25/2024 10:05:21 AM(UTC)
Electric Dryer Amana NED7300WW1 (Dryer Repair)
by AlexanderK 3/13/2024 1:37:06 PM(UTC)
Maytag electric dryer model LDE9306ACE (Dryer Repair)
by Guest 3/7/2024 9:11:14 AM(UTC)
Speed Queen electric dryer model LES17AWF (Dryer Repair)
by Guest 3/5/2024 10:42:09 AM(UTC)
LG DLEX5170V electric dryer won't start (Dryer Repair)
by Guest 2/23/2024 11:17:20 AM(UTC)
Kenmore electric dryer typical model 110.68522700 (Dryer Repair)
by Guest 2/22/2024 10:10:02 AM(UTC)
Maytag Electric dryer model MEDC300XW0 (Dryer Repair)
by Guest 2/6/2024 1:56:33 PM(UTC)
Maytag electric dryer blower wheel wear (Dryer Repair)
by Guest 1/1/2024 7:44:11 AM(UTC)
Speed Queen electric dryer model ADE3LRG8171TWoi (Dryer Repair)
by Guest 11/26/2023 2:53:33 AM(UTC)
Kenmore electric dryer model 110.68622700 (Dryer Repair)
by Guest 11/12/2023 6:47:37 PM(UTC)
Crosley electric dryer door handle part number (Dryer Repair)
by Guest 10/22/2023 1:05:15 PM(UTC)
Whirlpool Duet electric dryer model WED8300SW1 (Dryer Repair)
by Guest 9/9/2023 9:26:30 AM(UTC)
Frigidaire model ferb5700ds0 electric dryer (Dryer Repair)
by rnh7133 7/29/2023 6:22:58 AM(UTC)
Maytag electric dryer with coin type operation model MDE16CSAYW (Dryer Repair)
by Guest 6/29/2023 9:53:26 AM(UTC)
Older Speed Queen electric dryer (Dryer Repair)
by Guest 3/29/2023 5:23:19 AM(UTC)
