Lcren11
#1 Posted : Wednesday, March 25, 2009 3:09:19 PM(UTC)
Lcren11
It worked great until the other day when we decided to use the self cleaning feature. Now the oven is very clean but will not heat up at all, Bake or Broil. Does anybody have any suggestions. Thanks Larry
#2 Posted : Thursday, March 26, 2009 2:38:00 AM(UTC)
Replacement parts for WHIRLPOOL RBS305PDB8 | AppliancePartsPros.com
Here is a tech sheet
https://www.servicematters.com/d...0Sheet%20-%204451884.pdf
Turn your breakers off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker. If this does nothing it is best to measure the voltage at the oven.
Try cutting power off to the unit for half an hour or so. A long shot but worth a try.
Since you have no errors I would check out the over temp thermostat.
Item 37 in the "Oven, literature" section.
Be sure to have the power off, remove a wire from one of it's connectors and check it with a meter. Should be 0 ohms.
Lcren11
#3 Posted : Wednesday, May 13, 2009 2:16:12 PM(UTC)
Lcren11
Originally Posted by: denman Go to Quoted Post
Denman, Took me awhile to find this post but wanted to let you know I replaced both upper and lower elements in oven because they looked fried and it did not help with my oven not working. where is the oven temp thermostat located? Does the oven have to be pulled out to get to it? thks Lcren11
#4 Posted : Wednesday, May 13, 2009 3:14:11 PM(UTC)
It looks like it is mounted on the outside oven the oven cavity wall so the oven will have to be pulled.
Note they call it a thermostat when in reality it is a thermal fuse.
Lcren11
#5 Posted : Wednesday, May 13, 2009 8:32:34 PM(UTC)
Lcren11
Ok, Thanks I'll get it pulled and check it out and will let you know. Thks again Lcren11
Lcren11
#6 Posted : Wednesday, May 20, 2009 3:53:01 PM(UTC)
Lcren11
Denman, Thanks for the help it was the thermal fuse thermostat!!!!!!One other thing while I have you, how do you get to the front door glass to clean? I took out screws but it will not let me remove cover. I did not want to force it and break it. Thks Lcren11
Lcren11
#7 Posted : Thursday, May 21, 2009 2:51:22 PM(UTC)
Lcren11
Hey its been a few days, anybody home!!!!!!!!!!!!!!!
#8 Posted : Friday, May 22, 2009 5:14:52 PM(UTC)
Been at the lake for a few days.
Anyways here is a manual which may help it is for a double oven but I think they use tha same doors as yours. Check out Page 4-14
https://secured.whirlpoo...524e76/$FILE/8178007.pdf
Lcren11
#9 Posted : Friday, May 22, 2009 7:03:21 PM(UTC)
Lcren11
Thanks Denman, Hope you had fun at the lake!!!!!!!!!!!!!Have a great weekend. Lcren11
Whirlpool Oven - Controls Don't Work (Oven Repair (including Ranges and Cooktops))
by Guest 3/25/2024 10:18:22 AM(UTC)
Multiple failures in Whirlpool oven? (Oven Repair (including Ranges and Cooktops))
by Guest 3/22/2024 6:55:50 AM(UTC)
Whirlpool Oven WFE770H0FZ2 (Oven Repair (including Ranges and Cooktops))
by Guest 2/9/2024 7:03:09 AM(UTC)
Whirlpool Oven GBD307PDS7 Shuts down and Upper Blower fan does NOT work (Oven Repair (including Ranges and Cooktops))
by rswilson1844 12/3/2023 11:18:33 AM(UTC)
Whirlpool Oven Cooling Fan (Oven Repair (including Ranges and Cooktops))
by Tfastle 11/21/2023 9:59:51 AM(UTC)
Whirlpool oven - only one heating element? (Oven Repair (including Ranges and Cooktops))
by smithhead 11/3/2023 2:42:01 PM(UTC)
Whirlpool Oven Temperature Low (Oven Repair (including Ranges and Cooktops))
by topthumb 1/23/2023 11:37:05 AM(UTC)
Whirlpool oven WFE505W0HB2 (Oven Repair (including Ranges and Cooktops))
by Guest 1/7/2023 5:44:02 AM(UTC)
Whirlpool oven broil element doesn't go off and code F3 E2 (Oven Repair (including Ranges and Cooktops))
by Right_to_Repair 3/29/2022 1:54:22 PM(UTC)
Whirlpool oven approximately (2006) (Oven Repair (including Ranges and Cooktops))
by Guest 2/28/2022 3:02:09 PM(UTC)
Whirlpool oven shuts off overnight (Oven Repair (including Ranges and Cooktops))
by Guest 4/15/2021 3:53:14 PM(UTC)
Kitchen Aid/whirlpool oven does not light on the first try (Oven Repair (including Ranges and Cooktops))
by Deintinis 11/22/2020 7:42:29 AM(UTC)
Whirlpool oven won’t stay lit (Oven Repair (including Ranges and Cooktops))
by jc0786 11/15/2020 7:11:47 AM(UTC)
Whirlpool Oven - RBS307PVS03 - Fuse for front control (Oven Repair (including Ranges and Cooktops))
by lmagdaleno 11/8/2020 11:50:57 AM(UTC)
Whirlpool oven & broiler wont start (Oven Repair (including Ranges and Cooktops))
by rstonina 5/13/2019 12:35:09 PM(UTC)
